Question about Microwave Ovens
It runs but does not heat up
Serial # trt 11 16055
It's the magnitron - chearper to buy a new microwave/replace item than to fix; sorry
Posted on Jan 09, 2013
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jan 09, 2013 | Improvements Stovetop Replacement Drip...
My Microsoft says H97 and won't start running and goes back to H97.
The "H97" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and Panasonic customer service to find the proper part for the microwave.
Oct 05, 2011 | Panasonic Microwave Ovens
Serial trr4315895 microwave md. mh3184xpq-o fan runs all time quit heating, smell smoke
your magnatron or magneto depending on model, has given up the ghost. The repair cost is almost as high as replacement.
Sorry
Dave
Jan 14, 2010 | Whirlpool MH3184XP Microwave Oven
Microwave runs, but not heating. Whirlpool Gold
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download Whirlpool owner's manuals and installation instructions (very handy when removing the oven form the wall for parts replacement) here.
You can find helpful exploded view diagrams and order parts here.
Nov 22, 2009 | Microwave Ovens
Runs normal but no longer heats anything. model # JVM1451BA 001 serial # RT9227675
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE WONT HEAT
the lock on the door could be loose so the microwave light will turn on but it wont heat u should press on the door or buy a new one emai me at chattarbox24_7@yahoo.com
Jul 21, 2009 | Microwave Ovens
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
Runs but won't heat
Does the turn table and interior light come on?
Nov 25, 2008 | GE JVM1870 Microwave Oven
Microwave serial # xr2004675 superba heating
If the door seals tight & properly and the fine screen / mesh in between the door glass panels is not damaged, there should be no leakage.
But the risk remains that moisture and food particles will get into cracks and crevices and lead to arcing or rust, both of which can eventually damage the mesh.
What is the small curved piece that's falling out? Can you post a photo of it?
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 29, 2008 | Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
