Question about Invacare Air Flotation Mattress Overlay with Manual PumpEach
NEED OPERATING MANUAL FOR INVACARE TURN 2 PLUS MATTRESS PUMP
  • 4 Answers
  1. Use the (M) Auto-Firm Button. Press the Auto-Firm Button to engage auto firm. The Mattress will become firm for nursing procedures. An indicator lights to notify the bed is in Auto-Firm mode. A timer will cancel auto firm in 30 Minutes. Should the nurse be called away, an unattended patient will not be left on a firm surface.
  2. Set the patient weight with the Weight selection buttons (G).
  3. Press the "Center" static Turning Mode button (I).
  4. Place the patient on the bed.
  5. Center the patient on the bed from side-to-side and head-to-foot.
  6. Use a regular pillow under the head for comfort and to prevent the head from rolling excessively.
  7. Raise side rails.
  8. Press the desired Turning Mode button (O).
  9. Press the Full Turn Range button (J).
  10. Set the Turn Interval time with the up/down buttons (L).
  11. If the patient feels the bed is too soft/hard press the up/down Comfort Range buttons accordingly (H).
Posted on Jan 19, 2013
Invacare Pronto M51 lights on controller blink 2 green 1 red
It means the battery voltage has dropped below the operating range of the chair electronics. Either need new batteries or maybe a charger and new batteries. There is always a chance of loose battery harness connections.
Jan 12, 2018 | Invacare Health & Beauty
Instruct on how blow mattress with vacumn
There aren't many vacuum cleaners these days that you can use to blow up a mattress. You need to be able to harness the 'blow', which is the byproduct of the suction. You used to be able to do this with cylinder vacuum cleaners. The air is sucked in one end and blows out of the other. The bag in the middle collects the dirt.
Get a manual foot pump or an electric mattress pump.
Feb 02, 2016 | Furniture
What is an air mattress?
An air mattress is a mattress that is blown up using an electric pump, manual pump or with your breath. They are then plugged and support the weight of the sleeper like a balloon.
Feb 20, 2013 | Camping, Backpacking & Hiking
An air mattress is a mattress that is blown up using anelectric pump, manual pump or with your breath. They are then plugged and support the weight of the sleeper like aballoon.
Jul 09, 2012 | Camping, Backpacking & Hiking
Need to find a dealer, repair site in myrtle beach south carolina
I did a search on the Invacare website and found the following: SOUTHEASTERN HEALTH PLUS, INC.
11816 HWY 17 BYPASS
MURRELLS INLET, SC 29576
Contact Info
PHONE: 843-651-5795
Looks like they are 13 miles from your location. Hope this helps. If you need to search for another local service center click on: http://www.invacare.com/cgi-bin/imhqprd/inv_dealer/dealer_Main.jsp?s=0
Dec 01, 2010 | Invacare Pronto M51 Power Wheelchair
I cannot find a manual for a blue magic super pump
See the instructions near the bottom of this web page: (picture at the top of pasted instuctions on th link)
http://www.abcwaterbed.com/pump2.htm
  1. IMPORTANT! - Unplug waterbed heater for safety
  2. Remove cap and seal and put aside in safe place.
  3. Remove any excess air from mattress - slide forearm or broom handle from the head of the bed toward the fill hole to move air pocket
  4. Attach the heavy duty hose to the hose valve coupling, connect to the waterbed mattress and other end to the pump intake side. Be sure to include O-rings. Gently push the coupling deep into the mattress.
  5. Attach garden hose to the discharge side of the pump, this hose goes to a tub, or a deep sink.
  6. Plug in the pump. When it starts it should have a low whirring sound, not a high whiny one. If water is not pumping immediately unplug the motor and check hose connections for tightness, verify there is no air in the mattress.
  7. As the pump removes the water, be sure the hose valve coupling at the mattress is pushed down in the mattress to maintain suction. Heavy phone books or other like items will help maintain proper position deep in the mattress.
  8. Keep pumping the water out and continuing to maintain the hose valve coupling position low in the mattress so it can keep pumping.
  9. Do not leave the pump or the area until finished. A dry pump can burn up.
  10. When the mattress is part way empty, you can place pillows under it at the head to help the water run downhill towards the hose valve coupling.
  11. Continue pumping until water flow stops or pump changes sound. The more water you get out, the easier your mattress will be to handle.
  12. If you are satisfied you have got as much water out as you can, remove the hose valve coupling and quickly replace the mattress seal and screw the cap on.
  13. If the mattress is to be stored for a period of time, pour in a large bottle of waterbed conditioner into the mattress before you cap and seal the mattress.
  14. We recommend rolling up the mattress from the head to the foot and carefully sliding one end into a wardrobe box. Another wardrobe box can be worked over the top of the mattress. Work one box into the other and seal both ends and tape the boxes together in the middle. You can now safely move the mattress.
  15. If you don't get enough water out, the fiber layers can easily slide out of position during moving and you may not be able to get them back into position when you fill the bed.
Nov 18, 2010 | Magic Pool & Spa
Need operating manual
goto invacare.com when the home page comes up on the left side of the page you will see product catalog under that select Wheelchairs and top end. Next screen select Power Wheelchairs. Next screen select Pronto Series. Next screen select non-powered seating. Next screen select Pronto M51 with Sure Step. That is the last screen on the left side you will see owners manual select that and you can print it out with Adobe. Good Luck Hope this helps
Oct 11, 2010 | Invacare Pronto M51 Power Wheelchair
What is Invacare Supply Group? I have a Lynx-3 scooter. The scooter is not functioning. When I turn the key, there are 5 flashes. What problem is indicated by the 5 flashes? I need my scooter to get to...
Really i don't know the charge. Contact Fixya Team on support@fixya.com
Visit http://safemanuals.com/user-guide-instructions-owner-manual/LYNX/4TS630A-_E
Cheers
Mar 11, 2010 | Invacare Supply Group Invacare Scooter...
Running hot
contact email vaigaienterprises@yahoo.co.in
Mar 25, 2009 | Invacare Supply Group Invacare Corp...
Invacare Air Flotation Mattress Overlay with Manual PumpEach Logo
104 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
