Question about Bose Lifestyle 38 System
No color when playing DVD
I have color when watching cbl/sat but when we try to watch a DVD we can see and hear everything but everything is in black and white. Please help
  • sisink Nov 13, 2008
    Same problem, but was fine until added Wii. Wii color is fine, but not DVDs, which are in black and white.  Don't see any place to change the region using set up.  Thanks
  • Anonymous Dec 27, 2008
    did you fix it? I have exactly the same after adding a Wii - thouigh the Wii doesnot go near the Bose unit - I have straight to the tele! B& W DVDs are only OK for so long!
  • 32 Answers
Your player is set to the wrong format ie either ntsc if your in europe or pal if your in america, you need to go to the setup and make sure the dvd setup is for your region. pal in europe,ntsc in america..most dvd players automatically switch.but sometimes people change the settings without knowing.
Posted on Jul 01, 2007
SOURCE:
Out of nowhere, the sound became extremely distorted for everything. Changed to several other inputs (DVD, CBL-SAT) but all were distorted
Bad connection? Unplug the sub to see if it has anything to do with the surround or coil on the sub speaker. Connect the cubes separately to test.
Jan 03, 2014 | Bose Audio Players & Recorders
My daughter sat on her JVC tv/DVD combo LTdd42J remote and now her DVD's only play in black and white, when watching the TV the colour is fine. I have tried looking in the settings but cannot fin
Cable damage is the first thing to check. If the cable is external this is an easy check by trying a new one. Otherwise it is probably internal cable damage or damage to the video output plug.
Feb 18, 2013 | JVC XV-S302 DVD Player
I have a Sony trinitron model KV 2135M3 and I have just bought this Sony DVD player (SR 200p). When I watch VCD the color is clear and excellent but when I use dvd the color automatically changes to black...
dear your tv have three color systems and when you play vcd which is recorded in pal and you watched color when you play dvd which is recorded in ntsc system which is not available in your tv so you watch as black and white
Feb 10, 2018 | Sony Televison & Video
Valor IDA 700w won't play movies
TRY CONECCTING THE BLACK/GREEN CABLE TO GROUND
Nov 21, 2008 | Panasonic DV-169 Valor DVD/VCD/CD/MP3...
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
Dec 08, 2007 | Sony DVP-NS315 DVD Player
My DVD player, stopped playing in color!
check to see if the coding is set to PAL or NTSC, when watching in PAL, NTSC shows up in black and white. ( NTSC is normal for the USA and a hand full of other countries... PAL is used in ASIA, EUROPE, and most everywhwere else).
Oct 18, 2007 | Panasonic DVD-S29 DVD Player
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Jul 01, 2007 | RCA RCR450 Remote Control
DVDs Play in Black and White
this may be the problem with your dvd player
Feb 14, 2007 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Bose Lifestyle 38 System Logo
1,968 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
