Question about Vacuums
I can't get the plate off to see where the wires are that need replacing.
    Genius:
  • Vacuums Master
  • 1,669 Answers
Fred, it looks like you have the idea, but I believe you need a star drive bit set to open that vacuum. Be careful not to lose the screws!
Posted on Jan 10, 2013
The light on a fan is flickering. It doesn't appear to be the light bulbs. This fan has a remote control and it controls the fan OK and turns the light on and off but it flickers. What could be...
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Sep 22, 2011 | Vacuums
How do I replace carbon brushes in vax6131
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. Give that a try and let me know how that works for ya.
Jun 11, 2011 | Vacuums
Animal not picking up through main plate
Look underneath and you will see a short length of clear plastic hose with spiral wire reinforcing. Very often that hose splits (which allows air in and reduces suction around the brush roller) - you may need to get it off to inspect it thoroughly. To get it off, pull it off at the end closest to the motor and then unscrew it from the end near the brush. If it is split it will need replacing (a new one is not expensive, and it's false economy to try to tape over the old one - except as a very temporary measure).
If the hose is not split, look for a blockage somewhere.
Apr 09, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Pump needs replacing
I have the Bissell Big Green model 1672 and have used it for many years. Recently, the fan or suction blower began to emit a burnt smell so I shut it off. I had difficulty figuring out how to dissemble the top motor unit. Here is what I found.
Don't pry up on the very top disk, which is an air outlet. It will only break off and won't allow access to anything. If you do break it off, drill holes through the four posts and use stainless steel screws to re-attach the disk to the plastic posts it sits on.
Now, beneath the air outlet is the rest of the motor unit. The motor unit consists of three pieces. The bottom piece is the lid to the waste water receptacle. It is concave pointing down (lid shaped). The top piece is the domed lid for the motor unit. The middle piece is a flat plate between the other two pieces. The top of the flat plate (inside the unit) has mountings for the suction fan and the pump.
The flat plate is bolted to the bottom piece and the top piece (domed lid) is simply snapped down to the flat plate. If you take a flashlight and look inside the area where the AC cord is stored, you can see that the domed lid is a distinct piece from the flat plate. The model 1672 and 1680 (or 1680-3 if you wish) are nearly identilcal.
To access the internal parts in the motor unit, you cannot pry between bottom piece and the the flat plate because they are bolted together. But you can remove the top domed lid. To remove the domed lid, position the motor unit in front of you with the switches at 9 o-clock. Three snap-downs which attach the domed lid to the flat plate are at 1 o'clock, 2:30, and 7 o'clock. Wedge a flat bladed screwdriver or pocketknife between the edge of the domed lid and the flat plate at those locations and the lever the domed lid out and then up. The domed lid will separate from the bolted-together flat plate and bottom piece.
Wiring from the switches remain attached to to the electrical components. You will see that the AC cord has white, black, and green wires. The green ground wire connects to the fan ground at the 9 o'clock position. The white power connects to upper connector on the pump and also to the fan at the 7:30 position. Black feeds both switches on model 1672 and then a black wire runs from the correct switch to the bottom connector on the pump or to the connector on the fan at the 1:30 position.
Model 1680 has a third switch which feeds power to the floor sweeper. It has its own connection to the green ground and white power and goes through the third switch to connect to black.
If you need to replace the pump or the fan, shop around carefully. The pump, for example, can be found for $30 plus shipping2_bing.gif, but some will want to charge you $80.
Feb 15, 2010 | Bissell 1672 BIGgreen Wet/Dry Vacuum
How are the two top sections held together? I need to get at the wiring.
If you need to replace the pump or the fan, shop around carefully. The pump, for example, can be found for $30 plus shipping, but some will want to charge you $80.
Nov 30, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Just bought from garage sale: Circuit tested with meter, and seems intact; however no power to vacuum unit when switched on. Pump unit works ok.
You'll need to open up the top motor unit, check the switch for the suction and test the fan itself. My model 1672 ran for many years, but recently it started to smell burnt when the fan was on. When I opened it up, you could see the fan spitting out sparks. I suspect the brushes are gone.
Here are instructions for opening up the motor unit. Don't pry up on the very top disk, which is an air outlet. It will only break off and won't allow access to anything. If you do break it off, drill holes through the four posts and use stainless steel screws to re-attach the disk to the plastic posts it sits on.
If you need to replace the fan, shop around carefully. The pump, for example, can be found for $30 plus shipping2_bing.gif, but some will want to charge you $80.
Nov 16, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Pump will not run
You will need to disassemble the top motor unit and try putting power directly to the pump. The switch may be bad, the connections may be dislodged, or you may need to replace the pump. I am reading your question and I assume that you cannot hear the pump kick on (low thrumming sound).
Here is how to disassemble the motor unit. Don't pry up on the very top disk, which is an air outlet. It will only break off and won't allow access to anything. If you do break it off, drill holes through the four posts and use stainless steel screws to re-attach the disk to the plastic posts it sits on.
Nov 01, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
How do i open the power unit on a genesis 1672 vacuum cleaner?
I assume that yours is the same as the Bissell model 1672.
Here is how to disassemble the top motor unit. Don't pry up on the very top disk, which is an air outlet. It will only break off and won't allow access to anything. If you do break it off, drill holes through the four posts and use stainless steel screws to re-attach the disk to the plastic posts it sits on.
Sep 05, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
How do i get to the pump on a big green carpet machine
Jun 28, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Open power unit on Bissell 1672
Jan 08, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
