Question about Maytag MZD2766GES Side by Side Refrigerator
The prongs that push the ice out of my icemaker are constantly getting covered with ice and the icecubes are not completely solid. Because of the ice build up the prongs get stuck form time to time. Could it be possible they are rotating too fast or what other issues could it be?
    Sergeant:
    Champion:
  • 249 Answers
Call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Posted on Feb 14, 2013
  • Charlie Lapinski Feb 21, 2013
    what is your model number is then we can get started then okay
2 Suggested Answers
  • 686 Answers
SOURCE: Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Posted on Feb 26, 2009
I have a GE Adora side-by-side refrigerator Model # DSD26DHWA-BG. About 1 year ago the ice maker stopped producing ice. The mold that forms the ice cubes is filling up with water but never pushes out...
Hello, there are three screws that hold the icemaker in place if you remove these three screws and unplug the icemaker and remove it from the unit. After you take the icemaker out take the entire unit with the cover on it and run it under hot hot water this is actually quiet common for an icemaker to freeze up well actually its the parts on the inside of the icemaker that are freezeing up. After you defrost the icemaker as I term it then you would dry the icemaker and reinstall it. when the icemaker reaches 32 degrees the icemaker will call for water once again from the water valve if at this time after the ice forms the unit still doesnt drop the icecubes then you would have no other alternative then to buy another icemaker they usually sell for around 50-90 dollars american. The icemaker is not worth replacing parts on due to if you were to replace parts on the icemaker you would end up spending about 4 times as much as the entire icemaker costs. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks again Rick
Jun 04, 2011 | GE Refrigerators
My ice maker makes a popping noise when it getting ready to dump the icecubes..pops ten times then deposit ice into ice bin. is this a problem that needs attention?
...known problem with the samsung icemakers. Need to order a new icemaker. The new icemaker should come with a new control board with upgraded firmware.
Sep 29, 2010 | Samsung RS2630SH Side by Side Refrigerator
"space compact icemaker" cover fell off. How to put it back?
To replace this part, locate the two holes at the front of the top base of the ice maker, going up into the freezer ceiling. Place the two half-round 'pegs' at the top of the missing cover (above the vent holes) into these holes, then press the cover back into place. The peg protruding from the back of the piece should go into the hole in the ice maker housing, and the prongs will catch on the ice maker when you snap it into place by brute force. I wasn't strong enough to push it back on with one hand, but a stronger person did it in seconds once I explained how it should fit.
May 30, 2010 | Samsung RF197ABRS Bottom Freezer French...
I have hollow icecubes too, and water from the un frozen icecubes spills in bin and all the other cubes stick together. IS There Not a way to adjust the timer on the icemake to turn slower so they will...
your hollow cubes tells me your ice-mkr is not receiving enough water. first check water supply. does your refrig. have a water filter? also you could have a bad/restricted water valve.
Jul 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker tuns but ice does not drop out
OK the reason the Ice isn't dropping is that the element under the icecube tray isn't working. You'll need a new Ice tray with element I'd be guessing, but see how you can buy it. Some models you need a whole new ice maker. Cheers
May 21, 2009 | Samsung RM255LASH Side by Side...
Ice maker not making ice
see what postion the lever arm is may be is the water valve or the icemaker
Feb 24, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Where is the CCW setting on Ice Maker
not reccomnended to do its set from the manufacture, if you are experiencing smaller icecubes look into replacing your water filter or making sure water supply has not become resrticted
Oct 30, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker
pammytrent:
The icemaker only harvests / drops once the icemaker get to a temperature of Approx 15 Degrees.
Most manufactures Icemakers make approx 70 icecubes in a 24 period .
This can depend upon ambeint temp, use of product [opening closing of doors.
You will need to make sure the your condenser coil under the unit is clean.
Before cleaning disconnect power to unit first.
Air flow curculation in freezer can effect production also . too much food can restricting air flow, to little in freezer can effect ice production too .
hoping this helps
woodychoppers
Jul 07, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice maker leaking
what brand refrigerator?
Nov 27, 2007 | Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
44 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
