Water leaked on top of maytag front load washer. now inop
Have power to washer no response from switches. Control panel and indicators do not light up.
    New Friend:
    Problem Solver:
  • 10 Answers
Is this a stackable washer? my guess is that the main seal on the machine went bad.if its no longer powering up,i'm almost positive something has shorted out.you may have to replace the control board,and the seal at this point.in my experience,unless you can get a good deal with a certified repair man,buying a new machine would probably save you a bit of money in this case.it's hard to say exactly what the problem is.the water could have shorted out the brain"control module" or could have leaked to a point to where it could have fried the pigtail(power plug).but from the sound,i'm gonna have to say that machine is dead.no offense or anything.
Posted on Jan 09, 2013
4 Suggested Answers
SOURCE: my maytag front loader will not drain water oe comes on the control panel
On the 9700s it's even easier - three screws on the front bottom panel below the door, then use your hand to unscrew the large round handle in the front center. When you can't unscrew any more, pull gently and the filter / catcher will come out.
It's amazing how much stuff mine held - 4 breastfeeding shields, a pencil, a pen, a fake mouse, and lots of grey gunk.
Screw it back in, put the panel back on, and you're in business.
Posted on May 04, 2009
Maytag317
  • 1136 Answers
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
KevinWhite
  • 1902 Answers
SOURCE: I have a Maytag Performa
Hello & Welcome to FixYa
You can view this video for selector switch replacement:
Please get back to me with its model# if you have any other questions.
Kevin
Posted on Aug 25, 2011
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Why won't my maytag neptune front loading washer will not start?
Check out the door switch to make sure that it closes when you latch the front door. If it does not close the machine will be inoperative - safety measure.
Sep 19, 2017 | Maytag Neptune MAH5500B Front Load Washer
What does the code nd stands for on the maytag front load washer?
ND No Drain Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer. 1.Check for pump/drain restriction. 2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
May 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Start your wash machine
If your washer doesn't seem to work at all, check these: No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 01, 2010 | Maytag PAV2300 Top Load Washer
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Maytag Neptune top load. I am getting an od code
Be sure to unplug the washer before attempting any troubleshooting. On the Maytag Neptune the "OP" code indicates a problem at the door switch. These washers have a common problem associated with this code. The door isn't completely waterproof and allows water to get into the area where the lid switch is, corroding the electrical contacts and wires. Use a putty knife or screwdriver to open the top of the machine to access the door locks. Look for any broken or corroded wiring connections and reseat and clean as necessary. Test the switch using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty switch. Sure hope this helped and best wishes.
Sep 10, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
I hope this helps.
Vic
May 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
MAYTAG MAH5500BWW
No power
Lid switch
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
