Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
CAN'G CONNECT TO THE INTERNET.
Have put in new NIC and tried different cables.
The computer goes saying that a cable is unpluged with sometimes having a connecton for a second or two.
    President:
  • 1,214 Answers
How are you connecting to the router? Wireless, or wired?
If wired, is there a wired connectoid for a network card when you click on Start|Settings|Network Connections?
If wireless, is there a wireless connectoid for a wirless card when you click on Start|Settings|Network Connections?
Check out the manual here - www.westell.com/images/pdf/327w11_06_ug.pdf
Posted on Jan 20, 2009
Hiro h50015 nic on windows 7 says network cable unplugged when cable is clearly plugged in
To connect to the internet, you must have a device like a modem or a router. Is your PC connected to this device? Do you have other PCs or networked devices on your LAN? Can you reach them with ping?
To make it easier to help, you should give information how your network looks! e.g.
internet ---- cisco800 router --- d-Link switch ---- myPC
or something like that. Otherwise it is fooling around in the dark.
Apr 13, 2014 | Hiro H50015 Network Adapter
Tip
Tips for Media state Media disconnected or Network cable Unplugged
Wired adapter or NIC Local Area connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a physical device or connections
Solutions: 1. Try with a different port on the switch or the router. It could be the fault with the Router/Switch port 2. Try a different Ethernet cable. It could be the fault with the Ethernet cable 3. Try with a different NIC or a different computer. It could be the fault with the NIC
Wireless adapter or NIC
Wireless network connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a some device issue or the wireless settings
Solutions:
1. Try scanning for wireless network and reconnect 2. Remove the profile or preferred networks from its list 3. Check and make sure the SSID and the Security KEY are correct 4. Restart the computer 5. Try with different security types like WEP,WPA or WPA26. Check if the MAC filter on Router/Access point is enabled
on Aug 21, 2010 | Computers & Internet
Desktop pc windows 7 sp 1 wired cisco dpc 3008 no additional devices random connections
I would first get a new Ethernet cable and try it. If that doesn't fix it, call your cable company and have them do a diagnostic from their end. They can tell if it is their equipment or not. It their modem is OK, and the Ethernet cable is OK, then your LAN (Ethernet) card is either going bad, or possibly not completely inserted in the socket. To check: turn off and unplug your PC. Take the side off, look where the Ethernet cable goes into your computer. If it is on the motherboard, you may want to get a LAN card and use it instead of the onboard. If the cable goes into a card plugged into one of the slots, make sure it is fully inserted. If it is, you may want to get a new card.
Oct 28, 2017 | Cisco Linksys DPC3008 - cable modem
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
Fixable problem or motherboard going out?
Make sure that modem port is working. Check modem on other PC.
Use different LAN cable.
I suspect NIC failre... you can installa addtional a PCI Ethernet Card and disable integrated NIC.
Oct 20, 2009 | ASUS P4V8X-MX Motherboard
I have a new Netgear DG834(wired)from which I run my main PC & my daughters laptop & desktop PC's, one of the upstairs PC's suddenly cannot connect to the internet , the connection status icon in...
Hi more likely it seems to be an issue with the Ethernet card on the concerned computer. If you have a cross over cable then please connect that computer to another laptop and check if it still shows the error msg or shows connected. Let me know if you need any other help.
Sep 05, 2009 | NetGear DG834G Router
Wireless connection works but no plug in connection
The wired nic in your laptop will have a separate ip address than your wireless nic. I suspect you either have the router not set to hand out ip addresses, the info it is handing out is wrong, or you may have a static ip set. Did you ever have the laptop working on the wired nic?
Try disabling the wireless connection, plug up the cat 5 cable, open a dos prompt and type;
ipconfig /all
Notice the information. Now unplug the cable, enable the wireless connection and do the same for the wireless nic. The ip address should be different, but everything else should be the same. Let me know what you find.
Oct 12, 2008 | D-Link AirPlus DI-524 Wireless Router
NIC blinks on then off for longer run lines
You need to update the firmware of the router then hard reset it.
Download the router's firmware at www.linksys.com/download
After updating the firmware, you need to hard reset the router.
Press the reset button at the back of the router for 30 seconds then unplug the power for 30 secs then plug it back in. That should fix it.
Jul 01, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Verizon card with ps3
This can be accomplished by using a network cable called a crossover cable (cat5 type). This cable is used to connect two computers together. With everything off just to be safe connect your computer to the PS 3 using the LAN ports on each. Start the computer and get online with the um150 then turn on the PS 3. In Windowsxp go to start, programs,accessories,communications,
network setup wizard.Run the wizard. Click next twice and in the third window that pops up you should see Pantech usb modem which is the um150 and local area connection 1 for your computer.
Mine is realtek Ethernet NIC yours may be different but look to see if you have an ethernet connection with NIC in the description. If the box says that a cable or cables are disconnected click the ignore disconnected radial button and click next. In this window choose the top radial button that says
this computer connects directly to the internet. Continue through
the wizard, you won't need printer sharing, and it should have automatically checked the correct connections to be bridged. What this does is bridge the um150 with your NIC through to the PS 3 by the cable. Click next and name your computer and network, you can leave the defaults if you want. Click next to set up the network. At the last window you don't want to set up any other computers so choose the radial button that says "just finish the wizard" should be the last one. The downside to this is that the um150 uses a different IP address every time you connect to the internet so you will have to go through this procedure each time you connect. Now go to the PS 3 and network settings and choose check for wired connection and it should connect.
Dec 13, 2007 | Sony Playstation 3 (PS3) Console
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
75 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
