Question about Coffee Makers & Espresso Machines
Lost instructions for bush coffee machine cmm142
I have received this machine from a friend all the portafilter device missing and no idea how the steam vent works. So after a month of trying to search for the manual online I give in and need to ask for help. So anyone know roughly how this works Thanks in advance
JetJedi221
  • 25 Answers
SOURCE: steam wand
As the espresso is being made, you can steam the milk by opening the valve that goes to the wand. (sometimes there is a "switch")
To steam milk:
-Fill pitcher (or whichever container you want) with milk e**ugh for about 2/3 of your cup. A thermometer would be helpful.
-Place pitcher under the wand and lift it so that only 1/2 inch is under the surface of the milk.
-Open the steam valve. The milk will expand as it heats. Lower the pitcher to maintain the 1/2 inch depth. You should hear a "shushing" sound and have ** splattering.
-When milk is about 150 F (or preferred temp), close the steam valve and wipe the wand with a damp towel or else themilk will cake on the wand.
Good Luck
Posted on Mar 10, 2008
Ya1da
  • 4 Answers
SOURCE: can you give me the process to descale the miele cva 615 coffee machine?
Here you go just click on this link I put the manual on my site: http://yalda.us/CVA615_us[1].pdf
Posted on Mar 12, 2008
SOURCE: Need Instruction Manual for Saeco Magic Comfort Plus
http://products.saeco.com/index.asp?id_paese=7
follow the link to the instruction manual
Posted on Jan 02, 2009
  • 5 Answers
SOURCE: Needing a Francis Francis X3 portafilter and steam head
If you have no luck finding a FF! portafilter, you can use the ones from some Ascaso models. See http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html for more details.
Posted on Nov 06, 2009
  • 1089 Answers
SOURCE: No water coming through portafilter to make espresso.
You have a stuck check valve. Try running the pump with the steam knob open, then shutting it then, opening it 4 or 5 times and see if it will pop open. Make sure that you don't have the portafilter in at the time you are doing this.
Posted on Dec 03, 2009
Why won't my portafilter stay engaged once the water starts dripping? It flies off and sprays coffee grounds, and this started last week. Stays in place only if I wrestle with the filter handle.
It is possible that the grind you are using is too fine and causing so much back pressure that the portafilter is moving, also possible that the group gasket installed need to be replaced, I have also seen this happen with damaged screens.
Jul 27, 2015 | Rancilio SILVIA EXPRESSO MACHINE Silvia...
I just bought a Breville BES860 Fresca Espresso Machine and when I tried to put the basket into the portafilter, it doesn't fit. The portafilter came standard with the machine. Do I need a bigger...
They require a bit of effort to push them in when new, you should have gotten a set of single wall and dual wall baskets. There is a spring clip inside the grouphead (portafilter) and you have to overcome the clamping of the spring it is a reasonably tight fit to stop the basket retaining in the machine.
Jul 02, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Temperature problem
Keep portafilter in the head with no coffee in it at all times, preheat portafilter and cup before you brew a coffee.
Apr 25, 2010 | Rancilio Silvia Espresso Machine
Need portafilter plastic support peg
This merchant carries Saeco/Gaggia parts. You may have to get the disc and peg as a set. Part number/description is: "GG1038/01/A Crema disc for portafilter. Use with 2-cup basket"
Merchant site is here:
http://www.saecoparts.com/StarbucksSirenaespresso.html
The item is on the 3d row, 4th column
Nov 16, 2009 | Saeco Starbucks Sirena Espresso Machine
No water coming through - New Gaggia Baby Dose
Try this remove the portafilter, then press the button for brewing coffee and then turn on the machine, if both hoses are in the water reservoir, then water should flow out of the head after a few seconds.
Jul 20, 2009 | Gaggia Baby Espresso Machine
Makeing coffee
No, these machines use a pressurized portafilter to make brewing espresso easier. Be sure your coffee is ground about the fineness of table salt. Just level the coffee in the filter and insert the filter as instructed.
Mar 08, 2009 | Saeco VIA Venezia
Saeco portafilter instructions
When using ground coffee, use coarser grind like the size of table salt grain. Feel the ground coffee for adjustment. Do not tamp, just level the cup with coffee grounds and lock the portafilter into the group ring. Pull the handle all the way to the right and hold. Turn espresso hot water switch on. Hold the portafilter pulled all the way to the right for 5 seconds (pre-infusion pressure builds up to 9 bars). Release the handle at the end of 5 seconds. Espresso shots should be max. 2-Oz. in the cup. For larger quantity, use two shots. For an Americano, add hot water instead of allowing 8-Oz. water to pump through the coffee grounds.
Mar 05, 2009 | Saeco Aroma - Stainless-Steel
Coffee not pouring through portafilter
if your grounds are tamped down too tight, the steam can't get through it.
Dec 30, 2008 | Saeco VIA Venezia
I got used DElonghi bar 32 espresso, but may be missing part of portafilter.
it hard to judge but maybe if you put to mush coffee it hard to lock in place try puttimg less and try it tkanks foe using fixya pierre
Feb 06, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
