Question about Compaq Presario Notebook
Presario C500 laptop will not power on
I bought Laptop from a student she showed me with charged battery, it worked. As the power ran out, I plugged into wall ourlet and it showed that it was plugged in but after battery died so did the laptop.
* Light on front (orange looks like lighting bolt) is on when it's plugged into the wall (with or without battery)
* Battery is totally dead now, but when it had juice it turned on and can be ran.
* When I push the power button, it would start to boot up, then shut down as soon as it got to the windows screen, now the battery has no life to it what so ever. I trys to turn on then off in seconds, then the light on the front flashes (flickers)
* I have reseated the RAM... still no luck
The guy that ripped me off latter told me the HD went bad so he put in a HD from a simular model
How can I fix this problem, do I have to have the Motherboard replaced? or can it be fix... other words it is a ez fix, or costly.
Thanks for your help
  • ANThrx Feb 28, 2009
    I am having the same problem with my c500. I disassembled reseated ram.. removed and clean heat sink and fan.. clean processor reapplied thermo and reassembled... still does the exaxct same thing.
    Plug in laptop with battery in starts to post and i have about 5 seconds and can go into bios or F8 but in the almost same amount of time it shuts down again also with orange light on and lightning bolt. will not reboot unless i unplug and replug back in.... could it be the processor? kinda weird.
  • 76 Answers
Sorry. Good luck
Posted on Jul 20, 2009
My m2000 battery is not working
The possible causes are as follows:
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
Mar 31, 2013 | HP Compaq Presario V2000 Notebook
New battery charging very slowly?
Power off your Laptop, unplug the power cable from the laptop as well, take the battery out and wait for about 5 minutes. Put the battery back in, make sure it is seated properly. Plug the laptop back in and power it on an see if that charges the battery quicker. If it doesn't you may have a bad battery, and I would contact the place you bought it and ask for an exchange.
Oct 16, 2012 | Compaq Presario CQ61-310US Laptop
you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Aug 25, 2010 | Computers & Internet
Compaq presario C501nr wont charge battery
its in your power jack its a common problem try to check and change.
May 06, 2009 | Microsoft Compaq Presario C501nr Notebook
It will not come on. It shows in the mini screen
sir i want to download free soun driver for compaq c500 lapop
Apr 11, 2009 | Compaq Presario PCCOM2232US Notebook
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
Compaq Presario C500 will not power up
You should have a 1yr manufacturing warranty, or possible a store warranty depending on where you bought it. Take it to the store or send it to compaq. It sounds like a tech issue that you would have to test parts to find out.
Dec 12, 2008 | Compaq Presario Notebook
Presario V2000 battery not recognized
you may need to have that battery charge for a while, until it can be seen at charge level..or simply check the connections to see that there is no junk in the connector..
Nov 21, 2008 | HP Compaq Presario V2000 Notebook
Laptop not charging (Presairro C500)
Need to order for my Lap top Recovery Disk Need Phone No
my EM- IS Frances Lovegren lovetko8@fairpoint
Aug 18, 2008 | Compaq Presario Notebook
Battery shows 50% charge, but Laptop powers off
The battery is most likely bad. have you tryed another one?
May 23, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario Notebook Logo
284 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
