Question about Exercise & Fitness
Treadmill marquee mt8.12, e6 error. looking for owners manual
Incline motor will not operate, e6 eroor after 30secs
    Top Expert:
  • 12,223 Answers
Go and download free www.fitnessmanualsonline.com
causes: key safety+ elevation motor connection+screw binding.
solution: repair or replace s. key + test the connection e.motor + clean and lube the screw e.motor.
God bless you
Posted on Jan 09, 2013
3 Suggested Answers
SOURCE: Image 10.0 treadmill incline not working
I have a image 10.0 treadmill. I recently started running on it about 2 weeks now, my problem is that now when i put the red plastic card in the console to start it up, the console completely lights up and starts to buzz, and i won't start. I've unplugged it, it worked, then when i shut it off again and reinsert the red plastic card it does the same thing. What is this problemand what can i do?
Posted on Mar 23, 2010
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
How do I clear the E6 code in a Xterra 3.0 treadmill?
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
Also note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service.
Apr 05, 2017 | Exercise & Fitness
Error code E6 (XQB70-DB14)
24 Hour Locksmith Local Locksmith Locksmith Cheektowaga Ny 716 710 7399...
Aug 07, 2016 | Heating & Cooling
I have strength master treadmill when I put in on it show me E7 please what is the problem
May 03, 2016 | Exercise & Fitness
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Error code AC-6
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION ...ERROR 1-2: AC SERVO ERROR - MOTOR IS OVERHEATING (SPEED RESTRICTED ... error codes listed by category: treadmills, bikes, elliptical trainers.
[PDF]Precor Error Codes
Why is my true 400p stuck on maximum incline and will not lower?
It is likely the connections to the incline motor are loose or the incline motor itself is faulty. Refer Troubleshooting section in the manual which you can download from this site.
True Fitness RESIDENTIAL TREADMILL Owner Manual 400 ManualsOnline com
Aug 21, 2014 | Exercise & Fitness
I have an E6 error on my Marquee MT8.12 treadmill. we have tried to recalibrate but nothing happens
please follow the steps and fix it.
causes:safety key faulty +elevation motor not moving+elevation motor screw binding.
solution: replace the s.key +check connection motor +clean and lube the screw
Run again the s. calibration see the steps.
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Jan 09, 2013 | Exercise & Fitness
Hb pioneer pro treadmill gone to full incline with E6 fault code, how do i fix it
Please RUN the software calibration instruction is UNder the hood motor cover. and follow steps. this is for diagnose, troubleshooting and fix it.
then lubricate the gear and shaft elevation motor.
God bless you
Aug 05, 2012 | Exercise & Fitness
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
I have an Insight DK614 Tredmill that will not run. It displays an error message "E6" and the running deck will not lower. The motor is still running albeit at a much lower rate. No movement...
E6 or E7 An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait for 5-seconds and turn back ON.
Also, note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service. Treadmill Error Codes Troubleshooting
Oct 26, 2017 | Exercise & Fitness
Exercise & Fitness Logo
243 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
