Question about GE JGB500SEPSS 30" Freestanding Gas Ranwith 5 Sealed Burners, 5.0 cu. ft. Self Clean Oven, Non-Stick Griddle, PowerBoil Burner and TrueTemp Temperature Management System: Stainless Steel
How to shut off the oven
Shut off oven
    Problem Solver:
  • 9 Answers
Turn off the gas
Posted on Jan 08, 2013
Top main burner want turn off
Switch is either bad in it or has food/grease build up not letting it shut off.
Unless its a newer model and is push button?
Nov 12, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
Oven fan will not shut off
Do a search for thermal fuse and your model. The heat can trip a fuse which will lock the fan on. Good news is it is resettable. Find the fuse and reset it.
Oct 31, 2013 | Verona Cooktops
Frigidaire stove oven want come on model # FGF368GSJ
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Nov 06, 2012 | Frigidaire Stove/Oven/Range Cooktop -...
The ovens won't light, but the broiler does.
I think it saw it;s better days. time for a new one.
Nov 04, 2012 | Maytag MGR6875ADS
After running the self-clean feature on my 21 year old Beaumark stove all of the indicator lights (oven, burners)are not working. The clock (not digital) is not working either. Oven and burners are still...
you may have a temp thermo on the back or the top of oven . hi tempt would have shut off electrical . should have shut the oven off also / wiring in top may be faulty. now if the top burners are working but the clock & oven are not then you have a saftey thermo out . you may need to repl with new one . some ary resetable. take the old one to a appliance parts co . so they can read the tempt,s on it ,. should be able to match .. mm
Nov 20, 2009 | Cooktops
Oven wont turn off i unpluged it last night and it turned back on this morning when i pluged it back in
If you have turned the on/off switch to off and the oven stays on then the on/off switch contacts have fused together inside the switch.
If it were the thermostat it would get hot but would shut down in the off position
You need a need switch as simple as that
Jun 04, 2009 | Cooktops
Gas oven knobs seizing when oven hot
hi my name is mark, yes most manual gas valves can be disassembled and lubed. you will need gas valve grease. remember a little goes a long way and shut off the gas to the unit before disassembly.
Feb 21, 2009 | Cooktops
MAGIC CHEF GAS STOVE/OVEN TURNS ON & OFF
your technical support is horrible after being left on hold for so long and being told to pay 10.00 just to ask a question is poor business.
Nov 19, 2008 | Cooktops
Pilot lights
unplug the unit if the pilot ligth is electric.then u can use manualy.
Rv cooktop range 22 series
hi,
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Feb 25, 2008 | Cooktops
GE JGB500SEPSS 30" Freestanding Gas Ranwith 5 Sealed Burners, 5.0 cu. ft. Self Clean Oven, Non-Stick Griddle, PowerBoil Burner and TrueTemp Temperature Management System: Stainless Steel Logo
85 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
