Question about Peavey Escort 3000 300 Watt Portable PA Speaker System
Diagrama peavey escort 3000 - Peavey Escort 3000 300 Watt Portable PA Speaker System
5 Suggested Answers
  • 5603 Answers
SOURCE: two time the peavey escort 3000 fault dawn then a
Sounds like an imminent failure ready to happen. If it takes a bit of time before functioning, it may be getting overheated.
This is a small system... don't overdrive it as it is intended for SMALL venues of say 600 square feet.
Posted on Feb 11, 2011
  • 5603 Answers
SOURCE: the power of the Peavey Escort 3000 Portable PA
A failure probably occured in one of the power amps and has blown the fuse or worse. DO NOT replace the fuse and try to operate it as further damage may occur. Take it in for repair.
Posted on Feb 16, 2011
djredskyy
  • 670 Answers
SOURCE: PEAVEY ESCORT 3000 SOMETIMES THE
Are you Pushing the system over its limits by Peaking everything. Sometimes they auto Shut off if your pushing to hard.
Posted on May 13, 2011
  • 1156 Answers
SOURCE: I have a Peavey Escort
You can use the service manual for more tips..click on download ...
http://elektrotanya.com/peavey_cs3000_4000_4080.pdf/download.html
Hope it helped..
Posted on Jun 07, 2011
My peavy escort 1500 keeps shutting off but will come back on if I turn it off and on is it a fuse?
Can't be fuses, as it comes back on!
Questions:-
i) Does it go off when run continuously with volume controls at zero?
(this checks whether the audio output level is causing a problem).
ii) When the unit does operate, is the sound good on both speakers?
iii) Does the fault occur more when outdoors (wind noise tripping the power protection). If so, reduce the low freq EQ setting.
iii) Do the EQ lights flutter when the fault occurs?
This fault has been reported on the Escort 3000 too, see link
Peavey Escort 3000 sound cutting out - Peavey Forum
suggesting this may need a 'electronic modification' to put it right.
Hope this helps.
Dec 30, 2014 | Music
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Speaker jack
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Mar 25, 2014 | Peavey Escort 3000 300 Watt Portable PA...
PEAVEY ESCORT 3000 SOMETIMES THE EQUALIZER LEDS BLINKING AND STOP WORKING
May 13, 2011 | Peavey Escort 3000 300 Watt Portable PA...
The power of the Peavey Escort 3000 Portable PA Sound System went off while in use, and since then power is not showing any more
Feb 15, 2011 | Peavey Escort 3000 300 Watt Portable PA...
Two time the peavey escort 3000 fault dawn then a turn off and then turn on and funtion again.
Feb 10, 2011 | Peavey Escort 3000 Packaged PA Speaker...
Peavey Escort 3000 300 Watt Portable PA Speaker System Logo
464 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
