Question about Bushnell Weather FX5 5 Day Forecast AccuWeather Station - 950
I own a FX5 weather station and it will not receive a network signal. There are no signal strengh bars and i have moved the FX5 outside and still no results. Also it is showing low battery when the "NEW" batteries have a full charge. Any suggestions would be helpful, thank you.
3 Suggested Answers
SOURCE: I own three FX5 weather stations and none of these
me too i have been through 4 of the fx 5`s myself, they work from five days to two weeks then they quit, as there is NO place to register ? no instructions if you have to register ?, as far as i am concerned these are not worth the time, effort or mostly throwing your money away, and don`t try to call Bushnell, you will be put on hold, i guess everyone that got these for Christmas of 09 is calling about what to do with them, this may be one of the big mysterys of 09 not solved., and it does not matter what location you try from they just plain don`t work !! ` end of story!!!
Posted on Dec 30, 2009
SOURCE: the sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
Posted on Dec 08, 2012
My phone wont make or recieve calls inside my house
many will have problems inside some homes . especially metal sided ones if you live in a fringe reception area especially
Mar 05, 2017 | Cell Phones
My sensor isn't sending signals to main unit for outside temperature .This unit is brand new and has new batteries
  • Remove all batteries from both units
  • Install batteries in sender. Allow time for sender to initialize and begin sending signal
  • Install batteries in receiver. You should see outside temperature displayed
Dec 29, 2016 | Measuring Tools & Sensors
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
Next tech weather station is. Not w
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
Jul 01, 2014 | Acu-Rite Acurite Wireless Weather...
Auriol 4-LD3091 weather station will not pick up sensor
I had the same problem and gave up on the unit for a while, then I had another attempt and found this worked for me. Take the batteries out of both units (receiver and outside sender) then reinsert the batteries BUT put the batteries into the outside sender unit FIRST, this seems to make the difference as when you then put the batteries into the indoor base-station it detects the outside temperature signal immediately as it starts to set itself up .
Aug 18, 2012 | Measuring Tools & Sensors
WEATHER STATION AC100MB stops transmitting outdoor temp
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
Mar 20, 2012 | 3M Measuring Tools & Sensors
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Sep 18, 2010 | Acu-Rite Acurite Wireless Weather...
I own three FX5 weather stations and none of these units will receive a network signal. The units worked five for about a month but now it will only search for a network. I have even moved the unit outside...
Sep 29, 2009 | Bushnell 5 Day Weather Station Battery
Bushnell Weather FX5 5 Day Forecast AccuWeather Station - 950 Logo
Top Bushnell Measuring Tools & Sensors Experts
Ian
Level 1 Expert
Vernon Taylor
Are you a Bushnell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
