Question about Garden
Will not fire when switch is turned to start
Battery is charged
  • 755 Answers
Will not crank or will not fire? Most modern lawn mowers only use the battery for lights and turning the starter. If your battery wont turn the starter take it out and have it load tested at the parts store. You may find the battery doesnt have enough amperage to run the starter motor.
Posted on Jan 26, 2013
I have a 1990 ford ranger truck that just want start battery has fire new cilon but no power. Starter is fine I'm a female and I just don't know what else it could be I've ask and nothing help.
well this is your first request with fixya ----battery has a charge is it turning over and not starting --or not turning over --if turning over try spraying the carb with starter fluid if starts fuel problem --fuel pump --inertia switch --relay-fuel filter --////if no start electrical---//distributor--battery ignition -coil etc the following link shows how to check the inertia switch
How to Check Inertia Switch on Ford Vehicle Fuel Systems and this is link is a free online repair manual which can assist you with repairs
Free Online Auto Repair Manuals and Free Auto Repair Diagrams
Oct 11, 2016 | 1990 Ford Ranger SuperCab
First noticed the idle was really high last night when I started it. It returned to normal pretty quick. Battery light was on fire a minute it went off, battery is only 4 months old. Today, riding home...
sounds like the charging system is not charging when the battery is low the starter will not disengage properly disconnect battery and charge it while battery is out with bike in a high gear 4th 5th push bike back and forth this should unengage starter once your battery is charged and back in bike if the starter engages and dis engages properly then you will need to test your stator output with a multi meter look on you tube for video to test stator good luck
Mar 17, 2015 | Motorcycles
TRIED TO START 2002 DYNA LOW RIDER. turned key on,run switch to run and hit satr it turned over and fired once then nothing ,did not click or turn over when hitting start. waited a while and tried again...
Make sure battery has a full charge and both positive and negitave battery connections are clean and tight.Make sure unit is in nuteral and try to crank. If engine wont crank check starter selonid or relay. MAKE SURE BATTERY HAS A FULL CHARGE.
Mar 16, 2014 | 2002 Harley Davidson FXDL Dyna Low Rider
Scotts S2046 Lawn Tractor electrical problem. Charged the battery, turned the switch and started right up. Put on the mower deck, turned the switch, nothing. Checked fuse, checked wiring connections but...
A couple of things -
*The battery could not be fully charged and starting depleted the battery reserve. Recharge and try again. Battery should read ~12.5volts fulled charged and not drop below about 10.5-11volts as you crank.
*Disconnect the deck and try it again. You may have cut/pinched a wire that grounded some part of the start system, There may be a connector to the deck that is not connected and your safeties are not letting it crank.
Dec 08, 2017 | Garden
My harley 1200c sportser 2004 isnt starting after a new battery was installed. was told i didnt have to charge the battery it would charge itself in 90 mins ,one those fill cell batteries can you help
The cells are full? Check the battery with a volt meter - should read at least 11 volts on the DC scale, to be able to start your motorcycle. If it is at 11 volts, you really need to charge it.
If volts are good, check volts on the starter side of the solenoid with the run switch in the ON position and the key in start position. No volts = bad solenoid.
Jan 15, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
My riding mower won't start. It's a Craftsman
Check your seat switch and brake switch for loose wires.Most likely brake switch do to no spark at plugs,see if PTO switch/lever isnt on.
Nov 22, 2009 | Craftsman Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
