Question about Compaq Computers & Internet
Replace relay on compaq laptop
Cq61-420us notebook needs relay to power up
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    New Friend:
  • 11 Answers
Hardware issue,
you may check how to fix common pc errors on
http://digitalpowering.blogspot.com/2013/01/fix-common-pc-computer-problems.html
Posted on Jan 09, 2013
2 Suggested Answers
wellanny
  • 70 Answers
SOURCE: 4400mAh Replacement for HP Compaq 6510B Battery
you can get your answer here .
Posted on Feb 05, 2010
My hp compaq 6910p laptop not on adapter is ok **** i plug in laptop no power on no any light on
Unplug adapter using cheap multimeter, check for voltage on the Plug the goes to laptop.. the plug should be producing 13+ volts ( not sure exactly of Spec, but it is located on the power pack itself. )
Your problem sounds to me like your power supply is shorting out .
Alternative problem is the charge circuit on the mainboard may need to be serviced. ( commonly replacing mainboard- some facilites can repair )
Jan 12, 2012 | HP Compaq 6910p Notebook PC PC Notebook
I am unable to charge mt battery on an HP Compaq nx6235. It will not work even with the power cable pluf=gged in. Tried everything but unabke to get any power
You can try hp compaq nc6120 battery as a replacement battery for your HP COMPAQ laptop. The Business Notebook NC6120 battery meet or exceed the original Business Notebook NC6120 notebook/PC batteries. Buy this rechargeable Li-ion HP COMPAQ Business Notebook nc6120 battery pack is cost-effective now.
Sep 14, 2011 | HP Compaq nx6325 Notebook
Compaq Presario 2700US Notebook PC will not power up. Green power light is on
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced
Sep 16, 2010 | Compaq Presario 2700 Notebook
Black sreem on a compaq labtop cq50-215NR compaq
1 disconnect the AC adapter and remove the battery from the laptop
2. Press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter to the laptop
4. turn On the notebook and check.
If the issue persists, restart the notebook and press F10 to check if you see the BIOS screen. If you cannot see the BIOS screen then the issue could be hardware issue and your laptop needs to be repaired
Jun 16, 2010 | Compaq Computers & Internet
Hp compaq 6720 laptop, wont charge battery, bought new battery have same problem. have tried several different chargers and they are all working, but not charging battery
If the notebook does not charge even after replacing it with new battery and checking with several chargers then it is laptop power jack issue.
You may need to replace it. However to confirm the issue is with power jack just remove the battery and try to power on the notebook only with AC adapter. If it does not then it is the power jack which is allowing the ac power to be charged.
If your notebook is in warranty then you can ship it to HP and if it is out of warranty then check the link below, you can purchase the power jack of the laptop from here.
http://www.laptopjacks.com/parts/HP-6720s-laptop-parts-466.html
May 27, 2010 | HP Compaq 6720s Notebook
Need ac adapter/power cord
You can get a replacement power cord for this laptop from any elctronic or computer store near you like Besbuy or Radioshack, of you can order it online from this sites.
http://www.nextag.com/compaq-presario-700-power-cord/products-html
http://www.bizrate.com/laptop-accessories/compaq-presario-700/
Apr 29, 2010 | Compaq Presario 700 470024-192 Notebook
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
Hi,My HP Compaq nc6000 just developed a problem of not coming on. I have checked the battery and its okay. I have blown its internal parts and it remained off. It only indicates the orange light for some...
try taking the battery out completely and see if the laptop runs of the main power from the outlet, if so then the battery may have a bad cell in it and would need to be replaced.
Primary Batteries
6-cell Lithium-Ion (4.4Ah) – standard
8-cell Lithium-Ion (4.4Ah) – optional
Power SupplyExternal 65 watt AC adapter
from looks of it the battery has gone bad
http://www.laptopbatterystore.com/product/2151/compaq-business-notebook-nc6000-batteries?utm_source=GoogleProducts&utm_medium=CSE&utm_campaign=Compaq/HP&utm_term=HP18S6-Compaq-Business-Notebook-NC6000-Battery
Aug 20, 2009 | HP Compaq nc6000 Notebook
Power-on password
You will need to remove the bios battery from the laptop (not the main battery) for one hour. replace it and try to reboot. if no good, contact HP
Jul 15, 2009 | HP Compaq nx6310 Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
