Fuses keep blowing
Whenever i turn on my receiver my fuzes keep blowing but the system turns on and everything works but the sound. i replaced the fuzes with the right ones and they still blow.
  • 119 Answers
Check the spkr imp. and if thats good make sure your levels are not to loud if all checks out you will need some service on the unit
Posted on Feb 25, 2009
My teac ag-680 fuse keep blowing everytime i replace it and plug the reciever up
are short in the audio output transistors may have been short since a channel 2 or maybe 4, also open resistance check carefully and change them after you put a 75w bulb in series 100w or where is the fuse clearly, you have to remove the fuse when you put the focus if all is well will turn on only a small incandescent and amplifier work well you put audio speakers and there will, if everything is well put the fuse back and ready.
Jan 14, 2013 | Teac AG-680 Receiver
XV HTD510 system keeps blowing internal fuse .
fuzes blow because something is overloading the equpment. First make sure you speaker wires are not shorted, or touching each other. If the speakers are not shorted out, unhook them completely and replace the fuze. turn on the equipment. if the fuze again blows (make sure its the same value fuze and not a higer rating) then you most likely have a shorted output transistor or transistors. In this case you will most likely need to take the device to an electronics service place, or if its under warranty send to the manufacture. Most often these devices cost more to fix than to replace, so its your call on that. If your handy with electronics, you could try and get the schemetic for the device and try to fix it yourself. If you have a shorted "final" or "output transistors" you most likely also have burned out driver transistors and also some resistors. It's unfortunate that today most things are "throw away". one more thing, if the device has a strong smell, then the chances are good that something burned out
Feb 21, 2011 | Pioneer HTD-510 System
The motor keeps blowing the in line fuse whenever
Ok, Now motor use "Special" fuses, it is like a Slow Blow, as when a Motor starts up it can and does draw many many times it's rated Current... I suspect you are NOT using the correct fuses/breaker, you sold try simply upping the Fuse rating, a bit, as long as you are sure that all is well. However you may find you actually have a fault?. Motor speed controllers, can work fine "Down Low" but when it is turned up to maximum it may draw so much current that the Fuse or breaker is tripped, or blown... have you checked out your motor rating versus fuse breaker rating, you need a bit of "Headroom" as stated with a motor. it draw as a lot of current and the system has to be flexible enough to accommodate this.
Mar 07, 2010 | Minn Kota 55 AutoPilot Universal Sonar...
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
My RCA 7.1 receiver keep blowing fuzes i replace them and then it blows them again when i turn it back on. everything else but the audio works. the model number is RV 3791F
Check your sprks make sure the imp. is correct and your not overloaded with spkrs per channel, lower volm and if all checks out you will have to get the unit in for service
Jan 20, 2009 | Audio Players & Recorders
Tv wont turn on keeps blowing fuze when powering up
Hi
The voltage tapping is set too low for the voltage you got at home. Make sure that you check.
Regards
Jan 07, 2009 | Sharp 27H-S60 TV
Turn signals
replace the turn sidnal switch on the steering colum
Nov 20, 2008 | 1995 Pontiac Grand Am
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Whenever I turn receiver on, it turns off almost immediately
The amplifier blew out (probably shorted and damaged when wire was loose, and gave out under load). It won't be cheap to repair....
Sep 12, 2007 | JVC RX-D301S Receiver
64 people viewed this question
 Grubhead
Grubhead
