Question about Vehicle Parts & Accessories
My alarm went off I pressed the buttons several times no my car will not start why?
The starter is not turmning over but it's a new starter I wonder if the alarm has a fail safe to shut the car off?
  • 139 Answers
What is the year, make and model of your vehicle? What is the brand and model of your security system?
Posted on Jan 09, 2013
5 Suggested Answers
  • 103 Answers
SOURCE: VIPER CE0890 My alarm started going
Turn ignition to the ON position, press and hold the valet switch under the dash. It should turn the LED light on solid
Posted on Aug 21, 2010
logosc75
  • 625 Answers
SOURCE: I had a remote starter
The factory alarm needs to be disarmed prior to remote starting the vehicle. You could either add a data door lock module (HODL5) to the 4113LX to disarm the alarm or, you could extend the light green with black from the 4113 and run the wire into the drivers door and connect to the brown at the power window master switch. Test this wire while turning the key in the door.
Posted on Jan 21, 2011
logosc75
  • 625 Answers
SOURCE: i have a new prestige car remote installed
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Posted on Jan 23, 2011
  • 132 Answers
SOURCE: Lost my remote viper remote
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Posted on Oct 15, 2011
Car is "dead" but battery/alternator/starter are all in working order. Hornet is causing this.
Sounds more like a faulty battery terminal to me from your description ,try cleaning and make sure its tight then smear with petroleum grease.Clean terminal with a kettle of hot water first
Jul 26, 2013 | Cars & Trucks
Have a 1999 yamaha 1200 xl wave runner when try to start nothing happens except start button lights up
Mine was doing the same thing it was the starter solenoid,may also be the starter if the motor does not crank over
Jun 11, 2013 | Water Sport
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
Alarm on 2004 kia spectra wont let me start car
If the alarm is aftermarket I would remove it , I see this problem several times a month , take a test light and test for power at the starter signal wire while someone turns the key to crank this is the small gauge wire going into starter,if there is no power at this wire it will not crank ,if you momentarily apply voltage to the starter signal wire it will crank( also check starter signal fuse)(most alarm systems have a starter interrupt system ,and the aftermarket alarms fail after a few years) Alot of people believe there alarm is factory because it was there when they bought it new but dealer do add alarms that are aftermarket to please there insurance companies
Nov 19, 2017 | Kia Spectra Cars & Trucks
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
Sep 16, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
Jan 23, 2011 | Prestige Remote Start
The alarm (that I didn't know I had) on my 1997 Toyota Corolla went off when I tried to jump start it, and now I can't start my car at all. There is a brand new battery in there now, and the alarm keeps...
Put the key in the ignition, and turn forward
all the way just before cranking. Then within
5 seconds, locate, press and hold in the
valet/overide button, found under the
dash area, (push button, spring loaded)
until the installed LED (the blinking light)
in your dash area goes on solid,
and the siren chirps once.
This should reset the alarm, and reset
the grounded relay on the starter wire,
allowing you to start the engine.
Jan 06, 2011 | Toyota Corolla Cars & Trucks
How can I disarm a prestige car alarm system without the remote? The owner cannot find the remote. The battery went dead and when we jump started it the alarm went off. If the drivers door is closed it...
find the program button and turn on ignition without starting the engine and press and hold the button till it goes steady
if it has a swith turn on and flip the switch till it goes on solid 1 or 2 x
Dec 10, 2009 | Prestige 2 Button Remote Security System...
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
Vehicle Parts & Accessories Logo
22 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
