GE WASHER, REPLACED TIMER THEN BIG SMOKE
OLDER GE WASHER, TIMER SEIZED, REPLACED TIMER WITH REBUILT, MACHINE RAN FOR A COUPLE OF MINUTES, THEN BIG SMOKE FROM AROUND TIMER. REPLACED TIMER WITH ANOTHER REBUILT, NO SMOKE BUT MACHINE WILL NOT RUN AT ALL, BELIEVE MACHINE WAS OK OTHERWISE BEFORE TIMER SEIZED AND NO BURNED WIRES VISIBLE
  • 15,935 Answers
Be sure you are using the EXACT replacement part. The wiring may be different if it is a "close" match.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
GE High Efficiency washer model WPRE6150KWT--there appears to be a problem with the timer. A 47-minute load was still running after 80 minutes and the timer displayed 23 minutes left in the cycle. I've...
I would check screens on valve and hoses to be sure they are not stopped up. Also an unbalanced load can cause that if it's a top loader. Suspension rods would be the problem in that case.
Oct 11, 2017 | GE Profile WPRE6150KWT Colossal Capacity...
My LG washing machine model Tromm front loader not working properly.If we set time for 1hour 30 minutes it is not running after 43rd minutes or SO.If timer problem,what to do.Advise please
Usually there is a timer relay that is in there that needs to be replaced ,check that out its a big cube looking thing with four or five prongs on the bottom for contactors
Mar 28, 2011 | LG WM-2277HW Front Load Washer
Washer will fill with water and drain, but it will not agitate spin or move the drum period. The lid switch seems to be working.
the pump is electric. separate from motor
to operate machine. Perhaps you motor is fried? remove belt from motor if motor works
transmission seized , rebuilt from Dasa Mfg
1-866-327-2634 required.
May 26, 2010 | GE WJRR4170E Top Load Washer
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Washing machine spins but won't drain!!
what make is the machine,kenmore,ge
Jun 19, 2009 | Washing Machines
Need to find an Eaton timer for a GE washing machine ( 20 yrs old) Eaton part number 114-317-20 1/3 rpm, 115 vac. thanks Bob Westerdale PS- not sure of the model number on the washer. label is missing.
What is the GE part number it ? What is exactly the problem with the timer? Is i the AC timer motor or is it the contacts? You may be able to disassemble the timer & repair it.
Ebay is also a source for older parts.
Jun 08, 2009 | GE WDSR2080D Top Load Washer
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Door locked, start pause light flashing
I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
Jun 11, 2008 | GE WSXH208A Front Load Washer
Inglis Washing Machine agitator not working right
washing machine will not aggitate will do the rest
Mar 27, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
141 people viewed this question
Top Washing Machines Experts
