Question about Yamaha RX-V640 6.1 Channels Receiver
Yamaha RX-V640 turns on/off with clicking noise repeatedly. Can I fix?
Device turns on then click and screen turns off, then click and on again repeats till turned off. for the second the screen lights up Volume is going up and down. Without any connections or with speakers connected - the same
  • Juan Pablo Apr 27, 2013
    i have a similar problem but not as bad. Without any source connected, I just turn it on and increase the volume a bit, it starts making popping noises. If I connect my ipod, I can hear the music, with the random popping and squicling noises. I connecte other devices to other inputs, same thing. I moved the speakers from A to B: same thing. I opened and sprayed contact cleanner to the volume controller, no help. Any other ideas?
SOURCE: Yamaha RX-V793 flashing light on volume control and no volume
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Posted on Sep 12, 2006
SOURCE: Yamaha RX-V1500 Shuts down after 2 seconds
This set is getting old and is in the Archives section of the Yamaha consumer guide area. But, you can still download the owners manual if you need one. If it is going into protection mode even when there are no speakers connected OR when the sound level is very, very low or zero it is not good news. Yes, unplugging the line cord will cause the protection system to reset itself. But, if it shuts itself off again soon after rebooting it is a sign of bad grease in the output stages -- in all probability. Let me explain: The audio output transistors are mounted to a large heatsink which keeps them cool during operation. They are electrically isolated from touching the heatsink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set). That is the most common cause of your symptoms. However, there are several other possibilities, but I give this explanation a 90% probability based on my experience.
Posted on Jun 17, 2007
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
  • 127 Answers
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Posted on Mar 02, 2010
SOURCE: Yamaha HTR-5940 won't stay on after thunderstorm
I have the same problem as you but no thunderstorm. Mine happened after I connected speakers with the unit operating and had a speaker wire short at the back of the unit. Got a whiff of smoke and now I have that DSL1U unit clicking same as you. Did anyone suggest a fix?
Posted on Apr 04, 2010
Can a yamaha natural sound AV RX - V640 accept a graphic eqaulizer ?
Most graphics connect via the tape 1 sockets. The tape player (if you have one) going into the graphics's tape ins and outs.
Jul 04, 2017 | RCA Audio Players & Recorders
I have a Yamaha RX-V640 AV receiver. When I turn on the system, one of the rear speakers makes a hissing noise and system goes in standby mode automatically. I have tried changing the speaker and speaker...
Hi
the noise that you hear is a static, on the main circuit some components needed to be replaced. dont connect the speakers while you have this problem it can burn the speakers
if you want to fix the Amp let me know
ecrdn@yahoo.com
Jack
Oct 12, 2010 | Yamaha Audio Players & Recorders
Yamaha Receiver RX-V3800 Rear Left surround click sound
It's possible it is some sort of interference pickup, but another possible I've come across a number of times on Yamahas is poor earth connections via the back panel.
All the circuit boards have earth connections on them and the screws holding them to the back panel form an earth bonding connection. Tighten all the screws on the back to eliminate this possibility. Costs nothing to try and may just solve it.
Jul 19, 2010 | Yamaha RX-V3800 Receiver
How to fix clutch noise in Yamaha RX 100
Hi, Rehan_thehun I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fronk Forks---Plunk
9. Gears---WHINE
10. Head Gasket---HISS
11. Hydraulic Lifters---TAP
12. Pistons---SLAP
13. Rear Shocks---SQUEAK
14. Shifting Trans---CLUNK
15. Solid Lifters---TICK
16. Starters---CLICK
17. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
My Red Yamaha RX 100 Team BHP
HELP 03 RX 1 CLUTCH RATTLE AT IDLE
Yamaha RX 100 Workshop Manual
OEM parts for Yamaha
Yamaha rx 100 Owners manual
Mar 08, 2010 | Yamaha Motorcycles
My RX V640 is 5 years old..no problems...no changes to the configuration. when I use to the DTV/Cable setting HDTV..video feed...stereo sound etc is fine. Lately when I try the DVD setting to record TV to...
theb best way to do this is to connect the DVR to the vhs unit and the vhs unit to the tv using red white and yellow for both connections. usually composite video 1,2,3 or 4. DO NOT involve the AVR at all, as it will cause your video and audio to be out of sync.The video will not be as sharp, until you play it threw an up-converting dvd or AVR.
Aug 19, 2009 | Yamaha RX-V640 6.1 Channels Receiver
YAMAHA NATURAL SOUND AV RECEIVER RX-V640
there should be a reset on the on screen menu
Jun 26, 2009 | Audio Players & Recorders
Display is permanently "off" on the Yamaha RX-V620
Sounds like the LED that lights up the display has burnt out. An easy fix, if you're not afraid to take the front panel apart and resolder a new one.
Feb 05, 2008 | Yamaha RX-V620 Receiver
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
Yamaha RX-V640 6.1 Channels Receiver Logo
257 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
