Question about Yamaha RX-V657 Receiver
The receiver shuts down when zone 2 is turned on
Whenever I select zone 2 (to turn on zone 2) the receiver completely losses power "turns off" as though it was switched off.
  • Joe Fletcber Jul 01, 2007
    Thanks, your advice pointed me to my speakers (all in the ceiling). I "adjusted" the wires to the most suspect speaker and what do you know, zone 2 is rockin'!
    President:
  • 3,130 Answers
Disconnect the speakers on Zone 2 and try to turn on the receiver again. If the receiver works, there is a shorted speaker wire, pinched wire, or a blown speaker on zone 2. Good Luck
Posted on Jul 01, 2007
  • Larry  Dillon
    Larry Dillon Jul 02, 2007
    Glad to hear it. Congrats!
SOURCE:
I have a Gateway Solo Pro 9300 laptop. Whenever I shut it down, the power light turns orange, and the backlight is still lit. Other than that, the hard drive and fans turn off. What does this mean. How can...
That means the computer is in 'Sleep' mode. To completely shut down the laptop, you can press the power button once and it will do a normal shut down.
May 08, 2011 | Computers & Internet
Zone 2 doesn't work. on set-up zone 2 is active. on the bottom panel when i select zone 2 it flashes zone 2 off. when i try to turn zone 2 on it turns the receiver off. this happens from the front...
Disconnect the speaker wires at the receiver for zone 2 then test zone 2 on again. If it stays on, disconnect the wires at the zone 2 speakers, make sure wires are separated then reconnect at the receiver and test again. If it still stays on, Your receiver is good, your wires are good, you need to connect one speaker at a time and test power again. When it shorts, pull the speaker and meter it for a short. If your not sure how to do this, take it to any local audio shop and they will usually test for free.
If you have a volume control on zone 2 speakers independent of the receiver, you need to pull it and check it as well for corrosion or shorts.
If at the first step, your receiver still shuts off, the problem is internal and will need to be serviced. If you need further help on this, post a reply or comment and I can help you further. Hope this does the trick!
Jul 05, 2010 | Onkyo TX-SR804 7.1 Channels Receiver
I cannot make any changes to my Zone 2 -- cannot change the volume or change the setting from what Zone 1 is on. A blinking symbol that looks like a mushroom appears when you are trying to switch between...
Hi.
Looks like the the unit is locked to region 1.
The Yamaha receiver you listed is region free, therefore I assume you are talking about a different unit, in that case give model please.
If you have the problem with a Yamaha RX-V661, then simply disconnect power cord for ten minutes. And disconnect from power all devices connected to the receiver.
This should reset the system.
Let me know in case it does not work.
Regards.
Nov 17, 2009 | Yamaha RX-V661 Receiver
My Denon AVR2308 is frustrating me. I am running two zones (5.1 in main and zone 2 out of rear surround). I have made the audio setting to allow Zone 2 on/off, but i am stuck on how to turn sound off in...
Greetings,
Unfortunately the AVR2308 does not have the zone 2 video output connector needed to pass video to a second zone. The AVR2808 was the first receiver in that year lineup to offer a video output to a second zone. There are many different types of video outputs on that receiver, but they are all associated with the Main zone. This is why you loose the video when you shut down the Main zone. With respect to your Zone 2; the small remote that came with the receiver should have all the power and volume features you need to operate Zone 2 while keeping the Main zone turned off. The only audio that can be passed to Zone 2 though has to be in an analogue format (using the red and white RCA connections). This receiver does not pass digital audio onto Zone 2. Best of luck!
Aug 21, 2009 | Denon AVR-2308CI
My reciever is shutting down completley when i try to turn on the second zone. i tried rewiring it but it still does it could it be the reciever or do i just have the settings incorrect?
if the reciever shut down with zone 2 on, zone 2 volume at -3 and nothing connected to zone 2 it needs repair if not reconnect the speakers to zone 2 speaker connections and make sure you do not have more than 4 pair of speakers with impedence matching volume controls or a impedence matching speaker selector box
Jun 15, 2009 | Denon AVR-785 Receiver
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Denon AVR-4802R automatically shuts off in multi-zone mode
i had the volume of the multi-zone tuned too high and was attenuating it in an external control box. Once i took the multi-zone volume down to -25db, the problem went way. My main zone was operating around -35db so did not have the problem.
Nov 23, 2008 | Denon AVR-4802 Receiver
Zone 2 problem
I know this is old and im sure you have it solved by now, but it might be a good idea to check the amp setting of Zone 2. Is it switched to Internal or external? I remember something strange about this amp in that when you change from using the rear surrounds and go to use them in Zone 2, it resets the amp setting or something like that. Hope it helps if you still need it.
Sep 15, 2008 | Yamaha RX-V659 Receiver
It keeps shutting off
If you have zone 2 active with the level turned up too much it will cut out the whole unit. Try disconnecting zone 2 speakers, then turn the volume level way down on zone 2 and it should stay on if that is the problem.
Jan 02, 2008 | Onkyo TX-SR803 Receiver
No power
your set needs a tech due to excessive voltage the regulator got very hot causing it to damage when opperating systems a fan is needed to cool it off.goodluck.
Mar 29, 2007 | Yamaha RX-V1500 Receiver
Yamaha RX-V657 Receiver Logo
327 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
