My Toshiba satellite will not boot up, HD is not listed in boot order list
  • 1,800 Answers
Insert cd of windosw Xp and make boot order starts from Cd rom First.
then choose repair.
Posted on Jan 20, 2009
Error code F3-F200-0002 on my toshiba laptop I was attemping to do factory reset I was given this error code how do I correct this?
reboot the laptop holding f8
a list of booting options should appear
click safe mode
run system restore
if you can't get that list check your bios to seee if the computer sees thata hd exists
Sep 07, 2013 | Toshiba Satellite Laptop with Intel Core 2...
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Toshiba support
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb42&url=&dialogID=111194172&stateId=1%200%20111190763
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-s5057 12" 1.66 Ghz...
Forgot bios password on satellite 1805-s274
If you are the original owner, Toshiba will unlock the bios code for a fee $100.00 a cheaper approach, go to www.ebay.com Type: bios password this will take you into a list of sellers to choose from, I suggest one that deals with Toshiba, "better chance of success"
Apr 23, 2012 | Toshiba Satellite 1805-S274 Notebook
I can't boot my CD XP,boot to other devices too.. can u help me?
You can select an alternate boot device by pressing F10 or F12 as the Toshiba is booting up. You will get a list of boot devices, move the left or right arrow to select the device you want to boot.
OR
Go into the BIOS configuration and change the boot order of the devices your want to boot up with.
Apr 06, 2011 | Toshiba Satellite A55-S326 Notebook
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
When I turn my Toshiba Satellite A50 on and Windows tries to boot I get the following: Windows could not start because the following file is missing or corrupt: WindowsSystem32ConfigSystem It then says:...
You need the Toshiba CD that says "Operating System"...
If the CD doesn't boot, then boot to the BIOS setup screen and change the boot order.
CD should be listed first.
Re-boot.
Sep 25, 2009 | Toshiba Satellite A50 Keyboard
My toshiba wont boot past the BIOS screen. What
Several things could be wrong, the most likely is a failed HD or damaged windows install. If you press F12 it should take yuo to the boot menu, reply back with the list of options and I'll take a look,
Chris
Aug 10, 2009 | Toshiba Satellite A85-S107 Notebook
Booting Notebook using external devices.
This should do it for you.
On the Phoenix BIOS:
Go to "Advanced BIOS Features".
Go to the "1st Boot device" and set it to "USB-ZIP".
(Phoenix BIOS, Revision 6. you need to go to the Boot Order screen and select "Harddisk" and hit enter, giving you a list of IDE hard drives this BIOS prefers to call a USB device an IDE harddrive)
Jan 09, 2009 | Toshiba Satellite P15-S420 Notebook
Audio speakers not functioning, help!
Hi Leon7, there is more than one driver for your Satellite A100-S8111TD notebook as listed one the link below.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1209157&rpn=PSAA0U&ct=DL&BV_SessionID=@@@@0584055190.1206837807@@@@&BV_EngineID=cccgadedjkjmfdecgfkceghdgngdgnj.0
There is (All I'll list is for Vista), Realtek Audio Driver for Windows Vista (v6.0.1.5343; 01-30-2007; 15.18M)
HD version. Realtek HD Audio Driver for Windows Vista (v6.0.1.5343; 01-25-2007; 15.18M)
Before you re-install make sure you remove any other driver listed in add/remove programs.
Good Luck & Kind Regards.
Mike
Mar 30, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
David Payne
David Payne
