Question about Microtek ScanMaker 4900 Flatbed Scanner
How to open the Epson Perfection 4990 scanner for cleaning?
I am trying to get inside under the glass to clean it. How to open it? JD cameramaster1@hotmail.com
4 Suggested Answers
SOURCE: Open to Clean Glass
This is a pain; MicroTek offers no instructions; proceed at your own risk, etc. Before you start, get some high-quality optics cleaning kit ready to go, and clean the outer glass perfectly, so you don't have to keep guessing whether remaining smudges are on the inside or out. Remove lid by simply lifting to 90 degree angle and then lifting upwards. Remove all cords, so lid is not connected anymore. You need a thick, strong paper clip. Unfold it so one part functions as a handle, leaving a short length suitable for poking into holes. Lock the chassis on your scanner (underside, coin in red button, turn to locked position). Now sit in chair in front of desk. Put scanner with buttons on your lap, glass towards you. Hold hinge side of scanner with left hand. Notice that there is a pin hole just to the outside of each hinge slot. Now comes the hard, you -might-break-something part. Use right hand to insert paper clip into rightmost hole. With left hand, put a fingernail in the gap where the lid is gonna come off. Press firmly (pretty darn hard, in my experience) with the paper clip to release the tab that holds the top in place while pulling with your fingernail. With luck, a slight pop and that side is done. Repeat on the other side. Note: don't let paper clip angle down towards bottom, slip past retaining tab, and poke into something vital. There is also a third clip dead center, but it seems to pop out with little effort. Unfortunately, you're still not done. There are two more clips about halfway down each side, and no visible way to depress them. You just have to lift up with a frightening amount of force until they make a big "pop" and hopefully don't break. Now the darn thing is still hooked at the front (where all the front panel buttons are). You want to kinda lift the back end up, jiggle, and then pull up and back (I busted one of my front hooks before I got it off). Now the top is still connected via a ribbon cable, but you can put the edge of the top into the lip of the bottom, hold the back of the top at a 90 degree angle, and clean that glass with your left hand. Get it perfect, because you don't want to have to be doing this again. I kept a very bright LED flashlight at hand so I could shine it at oblique angles to scan for smudges. Of course, your scanning element is more vulnerable to dust during this whole process, so try to do this in a relatively clean room, and try to get done quick without dumping any dust on the innards. Good luck, and join me in saying "I'll never buy another scanner that isn't designed to let me clean the inside glass!"
Posted on Apr 18, 2007
SOURCE: cleaning inside of glass scanmaker 4800
OK Just Stupid (G).... Open the lid, pull it up and off and you will see two screws below the hinges. If you have decided to purchase another scanner already, you are clear to proceed. Take these out, pry the halves apart until you hear a click. Push the upper section toward the control panel and the will come apart like a freshly caught oyster.
I would not only clean the inside of the glass, but would get a can of compressed air and blow the heck out of the area below the black thing. This should get most of the dust off of the mirrors (3).
I took mine apart and cleaned them, but, if you had problems opening the case, I definately would not try taking this assembly apart. It'll make you cuss.
Posted on Jan 02, 2008
SOURCE: Yellow Streak on Images
I took the scanner apart. Then using a dampened eyeglass cleaning cloth, I gently cleaned the 3 internal mirrors.
No more yellow streak! :)
Posted on May 28, 2008
Officejet 9600: vertical lines (4) in center of page when copying using ADF. No lines when copying from glass. I tried the cleaning procedures on your trouble shooting pages. They did not help. How ca
John:
When using the ADF, the scanner doesn't move. The long rectangular platen glass on the left side of the machine is used, not the large glass. I believe that if you clean the long, thin piece of glass on the left side of the platen, your lines will disappear.
May 21, 2014 | HP Officejet Pro 8600 e-All-in-One -...
The scanner glass inside is cloudy
I recommend you do not take off the glass. I have done it and was never able to get rid of the dust, which really shows up on every scan. The fogging has something to do with an optical coating on the underside of the glass. If I knew then what I know now, I would let it be. If the fogging doesn't show up in scans, leave it. If it really does show up, the glass itself is often held down by simple double stick tape. You try to keep the tape intact so you can put it back down. It may be strong enough that the plastic frame on top of it could snap. Do it in as clean (not dusty) environment as possible so dust does not drift down inside the scanner. Never touch the lamp or move the scan mechanism. Again, don't do it unless it's showing up on scan results. Sadly, nobody "fixes" scanners, they are disposable, like coffee pots, even if they cost 300.00.
Mar 12, 2014 | Epson Perfection 1650 Photo Flatbed...
I have an Epson 4990 the glass of which has been fogged and now seems to be getting worse. Otherwise the scanner works well.
There are few steps to fix this issue however you will be giving it a try and cannot guarantee fixed resolution. These steps are for professionals and trying so yourself may cause more damage to the scanner.
Removing and Cleaning Glass
Forum of Cleaning the Glass
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 11, 2011 | Epson Perfection 4490 Office Flatbed...
How can i serive estudio161
Hi how are you this is jack ... (jack_pak@hotmail.com)
Dear your copier e-studio 161
you open the upper glass(open the upper glass side cover open the all screw this cover).and clean the scanner lamp and scanner reflacters... when you clean it your copier copy quality much batter.. (BUT VERY CARE FULLY DONT DAMAGE EVERY THING)
PLEASE VOTE ME ..
Thanks .
Best Regards,
Jun 04, 2010 | Toshiba e-Studio 161 Copier Copier
How to clean the Epson Perfection 4990
I joined a free users group on Yahoo and downloaded the rememdy.
Jan 26, 2010 | Epson Perfection 4990 Flatbed Scanner
The inside of the glass needs to be cleaned. How
The 3170 has a screw in each of the two slots where the lid inserts into the scanner. Remove the lid, remove these screws, and then the top portion of the scanner with the glass slides forward and off. Mine was stiff getting it off, but with some slight twisting and a bit of force it came off. You can then clean the glass.
Sep 29, 2009 | Epson Perfection 3170 Flatbed Scanner
How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Jul 03, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Microtek ScanMaker 4900 Flatbed Scanner Logo
74 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Tony
shelmnot
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
