Question about LG NB2520A Speaker Bar System BRay Players
Lg nb2520a soundbar freezes
Volume goes loud
HOW CAN I MAKE A HARD RESET FOR AN LG SOUND BAR WITH CODE NB2420A
To do a hard reset for LG soundbar las450h or 550 series, long press the volume min button on the soundbar and sound effect button on the remote simultaneously for 10 secs and the soundbar screen will show reset mode. Switch off and switch on the soundbar.
Jun 02, 2016 | LG NB2420A 160W Sound Bar
No optical plug on TV we wish to use it with. Have an optical to analog converter but can't get it to work.
If the TV has analog audio outputs, then you need an analog to digital audio converter. These converters are not bi-directional; thus the input can't be used for an output signal. This isn't clear from your description above. If your converter has optical IN and analog out, you might be better off with an RCA audio (M/M) to 3.5 mm cable (M) or adapter (RCA F/F to 3.5 mm M).
An analog to digital audio converter is here: http://www.gefen.com/kvm/gtv-aaud-2-digaud.jsp?prod_id=5278 . There are some converters that aren't compatible with all devices; you might want to try a different one. If you do have the correct converter, double check if you have enabled the external audio output on your TV. This will be in the Audio sub-menu for most LG TVs.
I hope this helps.
Feb 10, 2016 | LG NB2520A Soundbar System with Dual BuiIn...
Why does my volume go out on my LG tv..makes a loud ticking sound then volume goes out
Audio amplifier failing or poor connection on board when hot. replace main board.
Oct 15, 2014 | LG 42LG50 42 in. LCD HDTV
Whats the code for my LG soundbar for my one for all urc 7140
3217 if you have the 2013 version of the remote (URC 7140 R003).
If yours is older, then the specific code isn't in the remote's memory. OneForAll suggests you contact their customer service number. It's in the user manual. They might be able to suggest an alternative code for an older soundbar that works just as well.
Jul 17, 2014 | LG NB2520A Soundbar System with Dual BuiIn...
I have an LG soundbar whats the code
If you're asking about the universal remote control set-up code to this device, check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Standby mode
If you have your soundbar connected via HDMI, look for an option to disable the link between your TV and your soundbar (when this option is on on the devices connected toghether, when you turn off/on any of them automatically does to the same with all devices).
Nov 21, 2013 | Boston Acoustics TVee Model 30 Soundbar...
My soiund bar keeps shutting down
shutting down or pausing/skipping/muting, can you just try this and let me know if its is the issue and we can go from there. Sometimes when devices are connected to other device via hdmi or optical they communicate more than sound and video but they actually can communicate "status", to make it simple one device could control another. It is a possibility that the sound bar is being instructed to shut down by another device.plug a device to you sound bar using a rca cable/phono jack(aux cable)if the same thing happens then it is in fact malfunctioning, in which case you should have the manufacture replace it
Mar 29, 2013 | LG NB2520A Soundbar System with Dual BuiIn...
Background noise
no problem with..record some part of the start with no voice just a 5-10 seconds remain quite...just kept running the recording...then start and record your voice after which install AudaCITY Software and drag your audio file in it and then select the first 5-19 seconds recording which was just the background kept recording selecting the part go to Effects -> Noise Removal then press Get Profile,
after which again select all the track by: Control + A key on PC and then go to Effects Noise Removal move the bar to the left side...and press ok/continue key....now your track is very much clean by the noise...and
for sound loudness select all the track and go to Effects -> Normalize then again Effects -> Amplify put the slider value to -0.1 of what the value is shown.
Jan 19, 2012 | Vizio VSB210WS Soundbar
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
LG NB2520A Speaker Bar System BRay Players Logo
78 people viewed this question
Computer Repairing
Computer Repairing
