Question about Maytag EPIC MFW9700S Front Load Washer
Maytag epic takes too long
My Maytag Epic is taking way too long to finish. When it says 2 minutes left, it's more like 15-20. Can something be wrong?
  • 409 Answers
SOURCE: maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Posted on Oct 03, 2008
SOURCE: Maytag Epic not draining.
i had the same problem a couple months ago---i couldnt figure out why it wasnt draining. It kept saying "F-21"...well i called a "expert" and all it was was the lent trap inside needed cleaning....which isnt in the manual.....it is located in the back---truthfully im not sure where.....you have to remove a bolt and some screws and pull off the back and then clean it......hopefully some of this helped you...
Posted on Feb 19, 2009
SOURCE: MAYTAG EPIC FRONTLOAD WASHER NOT DRAINING
The filter is in the front on this one. Under the door, there is another panel. There are 3 screws that a 1/4" nut driver takes off pretty easily. Get a bowl and bucket. There is a white screw cap that you should easily see. Open it slowly with the bowl underneath. Close it again when the bowl is filled and dump the bowl into the bucket. Repeat until no more water comes out then unscrew it completely. Clean out the trap and replace. There is a stop that prevents you from overtightening. See if that works. A six dollar nutdriver is easier and cheaper than any repairman.
Posted on Jul 20, 2009
  • 12 Answers
SOURCE: Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
Posted on Oct 04, 2009
SOURCE: Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Posted on Jan 26, 2010
Maytag epic electric dryer takes a long time to dry clothes
check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
Nov 17, 2013 | Dryers
Clothes are still very wet after cycle is over on maytag epic z
u might want to check your water pump take off that bottom panel there are 3 t20 troque bits at the bottom the pump should be in front then u take off the filter on the pump becareful its plastic and check to see if there is any objcets in that filter and check your drain hose two if that does not help u might have to replace the pump... good luck
Feb 08, 2010 | Maytag EPIC MFW9700S Front Load Washer
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer flashing 02 F. Maytag epic washer won't spin -flashing 02 F about 15 minutes into the cycle. We just had new electrical components put into it.
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
My Maytag epic he has F6 code
What is the model number of this unit. Should be inside the door on the frame. If you take off the bottom panel, there is a tech sheet in there that will tell you what that means. I don't know that one off the top of my head and I can't get at my work P.C.right now. It'll give good detail of what to look for on that tech sheet Let me know if you have any questions.
Mar 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic frontload dryer won't unlock
Hello, unplug the washer remove the lower front access panel, get to the switch and pull downward on the circullar shaped release tab. Now drain the machine manually, take the filter out of the pump and clean out. reassemble and test. good luck
Dec 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Reset childlock model mah2400aww
did you try to unplug the unit for 30 minutes
Oct 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic mfw9800tq - can't get spin cycle to start on any cycle. shows 1 minute left and will not spin
The lid switch is bad or either the water pump is bad .Will it drain water? I just did change the water pump on a friends Maytag. Good Luck!
barneyluc
Oct 03, 2008 | Maytag Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
21 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
