Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 Replace Chassis
A company took the chassis of the TV to get fixed but the company for some reason went out of business and the part was never returned!! Where can I purchase a Chassis?? Thanks
    Problem Solver:
  • 16 Answers
You can call mitsubishi to check on that part that they fix.
mitsu required to send the chassis for rebuilding because its NLA.
call mitsu for further assistance on this
Posted on Sep 20, 2009
WD-52525 will not turn on, Flashing Red light.
if that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Jun 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Hi, I have a Mitsubishi WD-52525, and have the Green Light of Death. I plan on replacing the capacitors, and have the Power Chassis out of the TV. However, I am having issues extracting the DM module...
The DM is the second board in the chassis from the right side looking in the rear. The first board is the FMT. The second is the DM, third is the Signal and the one which is sideway across the front is the Power board. The Chassis metal shields have to be removed to access the boards.
Dec 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubihi tv wd-52525will not Power On after plug power cord
These Units have had a lot of problems with bad capacitors all over the Main Chassis. Most of the repairs are fixed correctly by sending the Main Chassis to Mitsubishi for them to refurbish it. In order to do this a Qualified Mitsubishi Repair Facility would need to come out to your home and remove the Chassis and send it Mitsubishi. The repair cost normally runs around $800.00 to $900.00. I would all Mitsubishi and see if they would be willing to help with the repair cost. Their Customer Service # is 1800-332-2119.
They should also be able to get you in touch with a local Service who can help out.
I hope this helps,
Sky Assoc
Oct 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi dlp 52525 garbled rolling picture. Picture just colored lines, rolling slowly. Sound fine, fairly new lamp.
You most likely have defective capacitors in your electrical chassis. It's best to send the entire chassis back to the manufacturer for total rebuilding. The cost is about $350 + labor, unless you can remove the chassis yourself.
Good luck.
Aug 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
65 inch mitsubishi flickering timer
replace the dm capacitors. You can get the V26 Chassis DLP DM repair kit at the following link. the kit contains the capacitors and CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Getting to the chassis of mitsubishi wd-52525
This is not something that you should attempt on your own. There are dozens of capacitors on several different circuit boards that will need replacement. Furthermore, just the disassembly process is quite complicated and time consuming, not to mention locating all the bad caps and then the re-installation process afterwards.
Mitsubishi will rebuild this chassis at their facility. Contact them so they can locate a company in your area that can handle this for you. Be aware though that this can cost $600-$700 or more between parts and labor. Perhaps someone at Mitsubishi will help pay for this repair.
michtech
michtech
Feb 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 error code 34
replaced 2 capacitors 3300u/35v. At the power board.
do not tuch the rest of the chassis...............
Nov 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
52" mitsubishi wd-52525 brightness problem
That is the V26 chassis dlp. Which has been plauged with bad capacitors. I have serviced many mitsubishi DLPs and have found that there are 4 1000uf @16v capacitors on the FMT board that can give the video some problems they are C8F21, C8F22, C8F19, and C8F27. These chassis are a real bear to work on. I would recomend a service center that is authorized by mitsubishi do any repairs on that model. Mitsubishi has a list of authorized service centers on their website that you can look up by zipcode. If you need more help please let me know. I am very famillar with that chassis
Mar 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
712 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
