Question about Motorola Mobility RAZR V3
Phone will not take a charge or turn off. it says unable to charge
    Scholar:
  • 35 Answers
Have you tried another phone charger? I had a motorola charger that had a bad plug on it and it wouldn't connect right. The phone could recognize that the plug was connected, but could not route the voltage through it, thus telling me it was "unable to charge". If that's not it and another charger doesn't work either, look at the connector on the phone. See if there is any dirt or debris in it. If so, try to clean it out. Also, if you got the connector wet, it can corrode rather quickly. If this is the case, you may need to use a drop of isopropyl alcohol to clean the contacts. Hope this helps. Good luck.
Posted on Jul 01, 2007
Motorola Razr Unable to Charge ft. White Dot Turned Red?
  • Defective charger
  • Defective replacement battery
Jul 27, 2018 | Motorola Cell Phones
Unable to charge
motherboard is weekplz go to the motorola service centre
May 12, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Once i charge my phone i get a yellow light rather than green.
Leave it plugged in for a little while. When it's yellow it means that your phone is dead and it's charging up the battery. It will eventually turn on and the light will turn green.
May 03, 2009 | Motorola Mobility ROKR E8 Cellular Phone
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
V3 unable to charge
reflash the firmware this will correct the charging issues and if that does not fix it then have the mainboard replaced.
Feb 17, 2008 | Cell Phones
Phone says unable to charge
Try a different battery. If that doesnt work, it may be your charger port. Take an old tooth brush, turn off the phone spray alcahol on the toothbrush, and scrub the port on the phone. If that fails your charger port needs to be replaced. Check with your provider about the warranty. If its not under warranty, check my profile and we can help you for sure.
Jan 22, 2008 | Motorola Mobility SLVR L7 Cellular Phone
V3I, light turns on and then goes off. Unable to charge.
The phone usb needs to be either clean or replaced so take them to a repair center and have them service.
Oct 15, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Unable to charge
You mobile software has some problem get it check with some one professional or claim they warrenty if it is there
Sep 11, 2007 | Motorola Mobility RAZR V3
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Sep 01, 2007 | Motorola Mobility RAZR V3c Cellular Phone
V3 dead but keypad flashing
I had exactly the same problem. After unsucessfully looking for a solution on the net I removed the simm chip and set it aside. The next day, I put it on PC usb charge and left it overnight. The next day, I powered it up and it worked. I turned it off and replaced the simm and it is now working fine. Go figure...
Jul 29, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
52 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
