Question about RCA RV3693 Receiver
Problem with RCA receiver model RV 3791F
Hi i turned on my amp 1 day and then my fuses blew so I replaced them with the right fuses and they keep blowing everytime i turn the receiver on i really need help. everything turns on but there is no sound i think it might be my board or something but i hope not
Slinteriors
  • 8617 Answers
SOURCE: The Red,Blue,Green do not line up and keeps blowing fuse
you need to replace 3 items FL231, DL231, CL230 then resolder the vertical IC and flyback conections. You can get the three components under the RCA parts category at this link.
http://servicemanuals.vstore.ca/
Posted on Feb 04, 2009
  • 119 Answers
SOURCE: my RCA 7.1 receiver keep
Check your sprks make sure the imp. is correct and your not overloaded with spkrs per channel, lower volm and if all checks out you will have to get the unit in for service
Posted on Feb 25, 2009
  • 39 Answers
SOURCE: rca 52wh73
your initial problem was the fuse blowing. this is usually caused by bad solder connections on fly back transformer. resolder to solve blown fuse for convergence problem. now for no power check horizontal-output transistor for short. if unit tries to cycle off&on fly back is defective. if no start-up, check capacior in 6v-line center of deflection module in-between heat sink, the top will be raised up . 2200uf/25v replace mch
Posted on Mar 09, 2009
  • 4234 Answers
SOURCE: I have 500 watts RCA
Without knowing the model nuber for your unit, I can't give you specifics, but see the link below for a generic explanation of protect mode (Amp Err). If you can supply the model number and any other symptoms, I should be able to provide more details. For example:
1) Was the unit working and just stopped with this error?
2) If you let the unit cool, will it work for a while?
3) If you disconnect all speakers, does the message still come up?
Please provide the answers and I'll update this with more info.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Nov 10, 2010
ladywinn
  • 5138 Answers
SOURCE: rca 52wh74 keeps blowing power fuse, what might
Replace the 2 big capacitors and Fuse Resistor 10watt on board that has AC line cord that plugs into wall.
Posted on Nov 25, 2010
40 amp. fuse keeps blowing out on 2008 harley
You have a short. Check the insulation on all wiring that carries + voltage - possible that some wire may have lost insulation and is abutting some metal part shorting it out.
Aug 24, 2015 | 2008 Harley Davidson FXCWC Softail Rocker...
Why does a fuse blow in my JVC receiver Model AX-S331?
usually a crossed speaker wire, or overdriving the amp will cause a fuse to blow
Mar 21, 2013 | JVC Audio Players & Recorders
15 amp a/c clutch fuse keeps blowing. why is it doing this?
Sounds like the magnet in the a/c clutch has failed.
Jul 02, 2012 | 2001 Oldsmobile Aurora
I have a duo therm model 57915531. i have checked the breakers all the fuses and the thermostat. i have found a 3 amp fuse in the control panel of the roof unit. this fuse was blown. i replaced it and it...
That unit has a thermostat I believe and 12 or 24 volts to power it. The 3 amps tells me it may be either line or low voltage, see manual. the fuse blows due to a short in the control circuit, a transformer if low voltage.
Sep 10, 2011 | Dometic Rooftop RV Air Conditioner
I can't find auto converge choice in menu of rca 52" rear projection tv.model # R 52 WH 74.
You have 3 pico fuses by your fly-back transformer. One of them blew that controls your convergence circuit. Your TV now thinks that it is a Basic CRT set with 1 tube. Find the bad fuse and replace with a 1/2 amp pico fuse, and re-solder all the pins of your fly-back transformer. Your menu should have the convergence option again.
Apr 27, 2011 | RCA HD52W59 HDTV Projection Television
Fuse Keeps Blowing
disconnect rca and speaker wires if they still blow you may have a problem with amp
Jan 17, 2010 | Volfenhag ZX-8400 Car Audio Amplifier
Jan 25, 2009 | RCA Scenium D40W20 40" Rear Projection...
My RCA 7.1 receiver keep blowing fuzes i replace them and then it blows them again when i turn it back on. everything else but the audio works. the model number is RV 3791F
Jan 20, 2009 | Audio Players & Recorders
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
