Question about Nintendo NES Console
Blank screen after installing new 72 pin connector
Today I installed a new 72 pin connector in my NES console. I put it all back together and the first three games I tried worked fine but then I put in another cartridge and the screen went this blank pink color. It has done that with every other game I've tried even the ones that worked before. I took my console apart again to see if I missed anything and it all looked good but it still doesn't work. Any ideas?
  • 1 more comment
  • bick32 Feb 07, 2009
    I have pretty much the same problem, only mine is totally black.
  • Anonymous Feb 23, 2009
    Red screen - since replacement of NEW 72 pin connector
  • Anonymous Apr 25, 2009
    dont know what to do mine is doing the same thing just with a white screen
frankgant
  • 250 Answers
SOURCE: please help! NES problem, and it's not the 72 pin connector.
It sounds like the pins on the game or the 72 pin connector in the console is dirty. Nornally the game connectors get dirty and when you put it in the console that transfers the dirt to the 72 pin connector. You need to purchase a cleaning kit from your local gamestop or other such store. Do Not Use Alcohol to clean your games or the console.
Posted on Sep 02, 2008
  • 36 Answers
SOURCE: Opening up NES console
to my knowledge no, all screws on the NES are phillips screws.
However,
If you see some funny star shaped screws then you need what they call a gamebit. Check ebay. There are two sizes of "gamebit" so if you need the tool check you get the right one.
Posted on Oct 24, 2008
SOURCE: I replaced the 72 pin
You may have damaged something on the board during the process. I suggest going over what you did, making sure the 72 pin connector is seated properly so the connection can be made cleanly, and if all else fails snag another one on ebay and try again...
Posted on Dec 04, 2008
SOURCE: Oringal NES
take it apart and remove the new pin. Clen where the pin connects with brasso, and a soft cloth. Repeat untill you dont get any more black on the cloth. Then remove brasso residue with windex and soft cloth. Make sure it is very dry. Put the pin back on and put it back together. It should now work like a charm.
Posted on Mar 02, 2009
SOURCE: NES in Black and white only...?!
I had the same problem but switching to an different TV fixed my problem.
Posted on Dec 05, 2009
Nes displays solid blue screen after i installed new 72 pin connector
Try cleaning the game packs out with qutips and rubbing alcohol too and the game port is dirty too try cleaning the game port out with compressed air cans.
Jul 23, 2012 | Nintendo NES Console
My Nintendo NES just keeps flashing on and off and the screen is flashing yellow. i opened the console up dusted out with compressed air. then i tried to fix the connectors on the 72 bit loader by pushing...
Rather than try to bend the pins back into place, you may have more success replacing them with a new 72 pin connector. You can find several merchants online that sell them.
Mar 07, 2011 | Nintendo NES Console
NES Glitching after New 72 Pin
You may have to face the possibility that the NES internal graphics card is old and now irreparably damaged. Unless you can procure and install another one, then the console may just be on its last legs
Jul 19, 2010 | Nintendo NES Console
Nes wonnt turn on, but when it does red light is flashing
Did you replace the 72 pin connector while it was apart? This is the number 1 reason for NES to fail to load or flash. A brief search of "72 pin connector" on eBay should net you a new connector for about $5 US.
If you have already done this, and the problem is really bad then recheck your work and make sure everything is connected tight.
Also consider that allot of nes games were not taken care of very well, so if the problem is specific to a couple cartridges, consider cleaning them as they are probably not connecting well.
Good luck.
Apr 02, 2010 | Nintendo Super NES Console
I have changed the pin connector on my nes, it does not flash anymore but now i get a blank screen can someone help me?
First try connecting through the av ports on the side of the console rather than the RF port on the rear of the unit.
If that doesn't work then your problem is likely a loose connection inside, go back in and reassemble.
I have had this issue with several consoles; these two solutions usually take care of it, though in rare cases a defective 72 pin connector was at fault even though it was brand new.
Good luck.
Mar 31, 2010 | Nintendo NES Console
Hi, I was wondering...how do you fix a NES which has been blinking? Like the screen flashing and restarting the game?
Replace the connector, these wear out over time. Here is a place I found thru Amazon that sells them:
http://www.amazon.com/New-Nintendo-72-pin-Connector-Guarantee-DS/dp/B000A3IA0Y
It will require you to take apart the system and to take out the old connector and replace it with the new one and then put the system back together and it will be like you have a whole new NES again.
Jan 23, 2010 | Nintendo Video Game Consoles & Games
I have installed the 72 pin, but the graphic, seem to work but dont quite line up, it is like the graphic are squares and distorted
The cartrage might not be inserted right or the 72 pin connector isnt lined up right so i would try installing it again.
Jun 29, 2009 | Nintendo NES Console
Nintendo NES Repair
It's as simple as unscrewing the console by removing all the screws from the bottom. Once inside take off the metal piece over the area where the game is inserted. Once under there you can remove the two screws that hold the 72 pin connector in and pull it out and slip a new one in. Put it back together in reverse.
Mar 26, 2008 | Nintendo NES Console
Oringal NES
It's still not getting full contact with the game cartridge. Try cleaning the contacts on the games with a q-tip and rubbing alcohol.
Dec 01, 2007 | Nintendo NES Console
Nintendo NES Console Logo
633 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
