Baxi bermuda GF3 pilot light goes out when fire is lit
Hi the back boiler works fine heating the radiators and hot water but if I turn the radiators off and light the fire the pilot light goes out after a couple of hours, there is no problem when I light the pilot light again Thanks Jim
  • jim fahy Jan 10, 2013
    HI the problem seems to be with the grey button that you push in to light pilot light when grey button is released pilot light sometimes goes out and sometimes it stays lit but after a day or so the pilot light will go out
  • 232 Answers
SOURCE: Have hot water but no radiators. Checked pilot
sounds like your circulating pump is bad or electronic zone valves
Posted on Oct 26, 2009
  • 36 Answers
SOURCE: boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Posted on Jan 31, 2010
  • 2518 Answers
SOURCE: got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Posted on Feb 20, 2010
SOURCE: ENGLAND, UK. DOMESTIC HOUSE CENTRAL HEATING. Baxi Bermuda
try bleeding the radiators in the order of downstairs first and then the upstairs and try to bleed them in the order they fill, trapped air can take a while to escape, a good sign on a radiator is the bottoms being warm where the tops( where the air is trapped) stays cooler, a sure sign to which radiator needs bleedin, hope this helps, colin
Posted on Apr 02, 2010
  • 120 Answers
SOURCE: how to light pilot light for baxi bermuda sp3
Go to this link.Bottom of page 15 on the manual
http://www.aroundtownflats.com/manuals/Boilers/Baxi/BAXI%20BERMUDA%20SP3%20GCNo.37-077-63.pdf
Basically it says (turn on the power first) Turn the knob to the the star/flame marking. Push the knob in, hold it for approximately 10 seconds. Release and check the small flame is lit. Now turn it to your desired heat setting.
Posted on Jul 21, 2010
Boiler not running smoothly
needs tune up change filter and nozzle and check electrodes are clean with no build up and clean out chambers
Oct 10, 2016 | Heating & Cooling
Instructions on how to re light my pilot light onb a baxi bermuda back boiler picture if possible thanks
http://www.baxi.co.uk/products/bermuda-back-boiler-unit.htm?view=download , i hope that will help
Feb 16, 2011 | Heating & Cooling
How to light pilot light for baxi bermuda sp3
Jul 21, 2010 | Heating & Cooling
Apr 02, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Feb 20, 2010 | Heating & Cooling
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
How to light pilot light on back boiler?
Hi. we have a baxi bermuda. I know that you need to hold in the silver button on the left while repeatedly pressing red/ignighter button until pilot is lit. Hold in the silver button for at least another 30 seconds.
Good luck, ours wont light anymore so was on here looking for advice.
Cheryl
May 07, 2009 | Kitchen Ranges
Baxi Boiler not firing, pilot light ok
first check the pilot is alight, it sounds like it is cause you can hear the boiler click. that click is the gas vale solenoid trying to open, if there is 240-230volts at gas valve when you here the click and pilot is alight the gas valve is broken. if you test for voltage look on the gas valve and see if its 240 or 24v obviously if it 24 v check for 24 volts, let me know
Nov 11, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
