Question about Lowrance Iway 500c GPS Receiver
Does not show my correct current location
Shows incorrect current position
I need to know the POLARITY of the AC adaptor to provide the correct setting using a universal adapter.
there is no polarity in ac current as ac means alternating current and that means alternating between positive to negative back to positive back to negative and so on
only dc ( direct current ) and the center pin of the plug is designated as the positive pole has polarity, the outer case being the negative
OR Are you asking the voltage of the ac adapter and the voltage of the dc output side of the adapter
Nov 26, 2015 | Office Equipment & Supplies
HDS Gens Touch shows positive red to negative & black to positive?
Lowrance may have goofed on the manual printing. RED is Positive, Black is negative. All these systems have reverse polarity protection. If you wire backwards, the screen will flash on and then automatically turn off.
I install these systems and I have always put the fuse hlder on the positive line at the battery. The fuse holders are always red wires and that may also lead to some confusion if they suggest attaching that to the black lead.
Hope this answers your question.
Jan 05, 2013 | Lowrance 000-10767-001 Hds-9M Gen2 Touch...
Somehow current time has changed and I DON'T KNOW HOW TO RESET
go to the settings of your phone and change the date/time settings according to your time zone
Nov 01, 2012 | LG Cell Phones
My monitor shows 'EE". what
According to your User Guide, 'EE' stands for Cuff has been placed incorrectly. Wrap the cuff properly so that it is positioned correctly. Also, did you move during measurement? Measure again and hold arm and wrist still.
If you continue to have a problem wit the unit, contact HoMedics (the manufacturer) Customer Service Dept @ 800-466-3342. 8:30am - 5pm ET, Monday - Friday.
Apr 04, 2011 | Walgreens Blood Pressure And Pulse Monitor
Se puede resetear el contador de los tambores de la oki c3400n
Trata esto:
When installing the C3400n printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result. Note: (Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
          0.408?openelement&fieldelemformat=gif
    >> Insure the toner is fully locked, see photo below showing the correct and incorrect positions of the locked toner cartridge.
CORRECT (Fully rotated to lock position)
    91.28a2?openelement&fieldelemformat=gif
INCORRECT (Not fully rotated to lock position)
179.32a2?openelement&fieldelemformat=gif
Dec 01, 2010 | OKI C3400n Laser Printer
My gps is showing the wrong current location. how
it hasnt linked to the satellites yet...make sure its fully charged, then slide the switch to the off position for 15 seconds, then power it back on and take the unit outside in clear view of the open sky and wait until the satellites lock on.
you can tell when the satellites are linked by the bar at the top in the main menu area..
bill
Dec 29, 2009 | Magellan Maestro 3140 GPS Devices
BMW X3 satnav showing incorrect position
there is procedure to adjust that , visit your bmw dealer
Feb 21, 2009 | 2009 BMW X3
Incorrect time showing on face clock
in that case... remeber to set your phone into an automatic time and date update. You can find it on the settings menu and there goes.. its done.
Feb 01, 2009 | HTC Touch Diamond Smartphone
Tomtom XL GPS shows an incorrect home location
change it through your gps
where you set favourites or home
it obviously did'nt set your correct settings through the map
make sure home settings on system itself are correct such as country city etc
Jan 06, 2009 | Tomtom One XL GPS Receiver
IPhone GPS not giving me the right location
This may seem like a silly question, but do you have GPS turned on in settings?
If you try to find your location without GPS on (it won't automatically turn it on) it will use cell towers to triangulate your position.
When your not using GPS, turn it off, it's a battery hog.
Good Luck,
Simon.
Was I Helpful? Let Me Know By Rating Me!
Nov 27, 2008 | Apple iPhone 3G
Lowrance Iway 500c GPS Receiver Logo
29 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
