Question about Crosley Traveler Turntable
I have a hitachi ks-2450h record player, it doesn't reject the records
3 Suggested Answers
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have purchased a Crosley cr40 mini turntable which has a american ac adpater. I bought a universal adaptor and my record player started spinning but a small plume of smoke started coming from the p
As grubhead implies, there is more to making a unit work on 'foreign' power than just making the plug fit in the socket. You don't say what was the input voltage used versus what it needs. It sounds like a 220 in to a 110 required device. Potentially it's toast unless the in-line fuse saved it. I'm sure the manual would have cautioned against what happened.
Posted on Nov 17, 2011
Rock ola 460
Contact the Guy at American Restoration in Las Vegas NV, he rebuilds these.
Jul 13, 2017 | Audio Players & Recorders
DVD recorder doesn't work
what is the problem, doesn't turn on or doesn't record .
Sep 27, 2012 | Televison & Video
Lg dvd recorder/vhs combo doesn't read dvds
Buy a DVD cleaning kit follow the instructions, sometimes brings it back to life. If no change! the assembly will need to be replaced,"not cost effective" cheaper to replace.
Mar 15, 2012 | LG XBR446 DVD Recorder/VCR
Samsung hr577a My DVD player WILL play 'burned' discs but rejects pre-recorded discs stating that the disc cannot be read or recorded to. Can you help
Possible that the player is region locked and so does not play discs from other format or mass recorded type.
You need to check with standard legal discs to see if this works , is so the player must be unlocked.
Please take an opinion from the dealership who sold this unit to confirm if this is covered under warranty.
Jul 08, 2011 | Televison & Video
Cannot record from tv to DVD Can play pre recordecdvd's
You cannot record from the TV as the TV doesn't give an output to the DVD Recorder.
You can only record onto DVDs from an external source such as Freeview, Cable or Satellite Box.
Jun 12, 2011 | LG DR-4912 DVD Recorder
I have a panasonic dmr-75v dvr and it won't read blank dvd's.i tried 3 different brands of dvd's with no luck of
This machine will only accept DVD-RAM & DVD-R Discs.
All other formats of Recordable DVD will be rejected for either Recording or Playback.
Please leave feedback.
Cheers
Andy
Jun 03, 2011 | Panasonic DMRES15 DVD Recorder
Want to know if it is possible to hear a record player through the AUX plug out? since my Yamaha RX-V396 receiver doesn't have a phono plug out
hi,
Only you can hear the record player through the aux of your amp if the record player comes with built in phono preamp. If not you need a phono preamp between the record player and amp or an amp which have a phono input. Phono preamp is available in the open market.
ok
May 22, 2011 | Yamaha RX-V396 Receiver
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
Crosley Traveler Turntable Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
