Question about Alpine iDA-X200 Car CD/ MP3 Player
Ipod suddenly not recognized by my car stereo (Alpine iDA-X200)
My Ipod nano (2nd gen) worked just fine when I first had the stereo installed and was fine for 3 weeks. All of a sudden, when I plug in the same Ipod nano, it shows as no USB device. Thus, I cannot use my Ipod in the car anymore, pretty much rendering my stereo useless. I live in a poor radio reception area. I don't know what happened. I don't see how any cords or wires could have come loose, but I can think of no other explination for this. Please help!
  • 1 more comment
  • BCValdez Feb 22, 2009
    Same thing happened to me. I've had the stereo for about 2 months, than all of a sudden the ipod wouldn't recognize the x200 as a compatible accessory. Defeats the purpose of having the deck if I can't use my ipod with it.
  • Anonymous Mar 20, 2009
    Same thing happened here only it lasted 1 day, well a day in a half. FUnny thing is if I use my friends ipod which is a shuffle, it works fine, go figure.
  • Anonymous May 11, 2009
    Same keeps happening to me as well, I think im going to try restoring the ipod. if not then im going to go with a flash drive.
5 Suggested Answers
HGComputers
  • 81 Answers
SOURCE: installing the Alpine IDA-X200
So it is powering up? On your actual deck will be a picture of the schematics of the wiring. With the system powered up, assuming you taped up the power wires, strip the front left wires coming from the deck and use them as your tester. You now know forsure they are for the front left so as you go through your cars audio wires you will find which wires are for which speakers around your car. Label them as you test them. Hope that helps.
Posted on Jan 14, 2009
  • 152 Answers
SOURCE: 2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
Posted on Mar 22, 2009
rcampsr
  • 90 Answers
SOURCE: Need to know what wires are for what to change out
The best thing you can do for your situation is to get a vehicle wiring diagram for your particular vehicle. This can be done at the dealer or by buying a vehicle manual at the autoparts store that has the wiring diagrams in it. You can then see the wiring color coding. They also make a factory plug pigtail that you can plug into your existing radio harness and then wire it correctly to the new radio. The new radio should have the wiring layout included with its documentation, and some radios also have small marking tabs on the wire ends to tell you what they are for. Good Luck, RAC
Posted on Apr 18, 2009
smarthome2
  • 1114 Answers
SOURCE: my alpine ida x200 keeps skipping during songs
All you can really do is use a CD Player cleaner *one that uses fluid* run it thru a couple times and try a disc again. Clean your CD's with liquid car polish an a microfibre towel, it works wonders for new and old CD's. If it still skips, It needs to be pulled for repair. They just replace the transport, usually runs between 100-150 depending on the service center. Hope this helps.
Posted on Aug 11, 2009
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
My alpine ida x200 keeps skipping during songs
Aug 11, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
I just had an alpine iDa-x200 interface unit installed in my car. It connected to my IPod fine the first day. Now it says "no usb device" I've checked the connections and they're fine. Why doesn't it...
Ive had the same problem with pioneer. I reset the unit and it worked once again but wasnt perfect. Id call Alpine cust. service tech to see about any "known" issues.
May 19, 2009 | Car Audio & Video
2nd gen nano not synching
DId you install Itunes?
Without Itunes the computer does not recognize the Ipod...
May 07, 2009 | Apple iPod nano
IPOD is hanging but can't be reset.
i would try reformatting your ipod to factory specs (can be easily done with itunes following the information provided at mac.com)
to reset the ipod, turn it off, then on -- then hold down the 'menu' key while pressing the center 'click' key until you get the apple logo. this just may solve the problem.
Apr 25, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
How do you install radio to account for usb port
ipod shows its connected but no audio comes out
Apr 18, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
2003 silverado z71
If not....
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Nano Will Charge on Laptop/ Will Not Sync & Will Not Connect to Itunes
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
Mar 19, 2008 | Apple iPod nano
Alpine iDA-X200 Car CD/ MP3 Player Logo
862 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
