Acer Aspire One  PC Notebook Logo
Anonymous Posted on Jan 08, 2013
Notebook screen is upside down
My screen has somehow turned upside down, so if i need to type i have to do it backwards
Gerald Manuel
Level 3:
  • Master 564 Answers
  • Posted on Jan 08, 2013
Gerald Manuel
Master
Level 3:
Answers
564
Questions
0
Helped
57571
Points
1495
Press Ctrl Alt and up arrow key
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
114
Points
16
On your desktop right-click empty space and choose Graphics Options then Rotation then Built-in Display (if its there) then Rotate to Normal.
You can also try a shortcut with your keyboard Hold-down CTRL+ALT and then hit the UP arrow key to rotate the screen back to 0 Degrees.
Upside down screen
Go to your control panel and then the Mfr display panel configuration settings - Find and click on "Restore Defaults " or just change the rotation back to upright if you like the other changes you previously made.
Dopo tablet screen backwards
I have the same problem with my dopo td1010 i used it on the city bus one day then put it in the case as i was walking home and took it out when i got home turned it on set it on the table went to us the broom came back and the screen was flipped upside down and backwards. I have had it for a year and a half with the screen like this and cant contact customer service because they wont pick up.
My bulb was replaced. We reset the bulb hours and somehow flipped the screen upside down. The projector is mounted upside down. What do I do? In trying to fix it, the remote quit working. I may have...
I guess you used factory reset, then picture flips back to table/ front mode.
In setting menu choose for ceiling ( R upside down icon) and set this to ON.
My Monitor Has Gone in Upside Down Positon
sure you have a Intel graphics card, with this cards you can turn the positioin of the screen pressing ctrl + alt + cursor (up, down, left, right)
try to press this combinations an you'll put your screen in order
bye
Carlos
Images upside down and backwards
The ADF does nothing more than feed the document into a position to be scanned, and has nothing to do with print issues " stripes" on print? Can you provide more details.
Typically you will find an icon near on the tray of the ADF which will display the proper orientation for the item to be scanned. If this is correct, then your software is somehow manipulating the image to a different orientation. You may want to check the scanned image before printing, and check the printer settings. More likely a printer problem, than a scanner problem as I have understood the issue thus far.
Image is upside down and words backwards
malfunction in the camera and will need repair
olympusamerica.com/repair
Monitor 2 - Image is upside down and backwards
Check your graphic card settings. I have a 6600gt, and can invert my screen. Try going: right click your desktop, select properties. Go the settings tab. Clieck advanced. There do you have a tab for your graphics card? Mine shows I have a 6600Gt. After selecting the tab it displays options. I have NVrotate. That rotates my screen.
Top screen
This is very unusual and I've never come across it. I can only think there has been some type of software corruption as you can not put the screen in backwards or upside down.
My toshiba data projector has somehow had the words and menus turned upside-down and backwards. I do not know what I pushed or selected to do this, but I have no idea how to get it back, please help me.
Greetings,
This is actually a feature. Most projectors, when mounted on a ceiling are turned upside down. You want to go into the menu and look for view. Then look for Vertical flip and Horizantal flip and make sure that they both say off. Let me know if you have any more questions.
-Take Care,
-WN
1helpful
Picture is upside down and backwards
I have the same problem. How and where does this come from? My camera was sitting in the dock when I noticed the problem!!
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
