Question about RCA RV3693 Receiver
RCA receiver model RV 3791F
Hi I need help i replaced my fuses after they blew and now everytime i turn my receiver on they blow i know there the right ones because i took my receiver to the store and asked them which ones it took. i already bought 3 pairs of them and they still blow everytime it turns on
techman
  • 3130 Answers
SOURCE: RCA 5-CD Shelf System, RS2654 Fuses
Never ever replace a fuse with a bigger one, you are lucky the unit did not blow up and statrt a fire. When a fuse blows there is usually a reason.There is a short in the main power supply or the output stage. You will need to test for shorts on the main transformer, B+ rectifiers and the main filter capacitors. If that does not show any shorts, you will need to test the audio output circuits for shorts on the audio output IC's. Good Luck
Posted on Mar 22, 2007
Slinteriors
  • 8617 Answers
SOURCE: RCA HomeTheater blew fuse. Replacing fuse just results in another blown fuse.
Check for a shorted horizontal output transistor.
Posted on Jan 31, 2008
SOURCE: RCA 64 inch rear projection tv with pip Guide+gold
Get a new TV
Posted on Feb 19, 2009
ladywinn
  • 5138 Answers
SOURCE: rca 50" dlp tv makes squeeling noise when turned on.
Color Wheel.
Posted on Feb 20, 2009
  • 119 Answers
SOURCE: my RCA 7.1 receiver keep
Check your sprks make sure the imp. is correct and your not overloaded with spkrs per channel, lower volm and if all checks out you will have to get the unit in for service
Posted on Feb 25, 2009
Why does a fuse blow in my JVC receiver Model AX-S331?
usually a crossed speaker wire, or overdriving the amp will cause a fuse to blow
Mar 21, 2013 | JVC Audio Players & Recorders
My fuse blew on my alpine amp and i need help replacing it? everytime i put a new one in it blows
the output devices in your amplifier are shorted.
to confirm,unhook the speakers,and turn on the amp.
if the fuse blows,the amp has a short inside .
Aug 30, 2009 | Alpine Car Audio & Video
Reverse lights fuse blew
hi
check the wire because if the fuse keep blowing there's a wire somewhere on the car that has contact with the frame so everytime you put your car on reverse the 12V wire shortcut on the frame so the fuse blow check all your positive wire and your bulb as well
Good luck
Jun 19, 2009 | 1997 Ford Explorer AWD
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
My RCA 7.1 receiver keep blowing fuzes i replace them and then it blows them again when i turn it back on. everything else but the audio works. the model number is RV 3791F
Jan 20, 2009 | Audio Players & Recorders
2001 toyota corolla blows 7.25 fuse when turn on ac
I would guess that your AC compresser clutch is shorted out. Try this: Look down into the area where the compresser is, and unplug the wire going to it. Replace the fuse, and try the switch. If the fuse does not blow, you need an AC clutch assembly. Let me know what you find out.
Hope this helps.
Oct 04, 2008 | 2001 Toyota Corolla
Fuses for P-07
the fuse you need is a t4al 250v
this is a common slow blow 250v 4amp fuse.
You can get them at RadioShack
Oct 03, 2008 | Gemini Sound Products P07 2-Channel...
Car audio
Does it blow the fuse if you disconnect the RCA cables and disconnect the speaker wires from the speaker terminals of the amp?
Does it only blow the fuse after the head unit is switched on (only after remote voltage is applied to the amp)?
Apr 28, 2008 | Car Audio & Video
Amp blowing fuses
The amplifier probably has shorted output transistors.
Disconnect the speakers and RCA cables. Replace the fuses with two 10 amp fuses or a single 20 amp fuse. If the amp blows the fuse when it powers up, the outputs are almost certainly the problem. Don't try it with the two 30 amp fuses. The smaller fuses will provide more protection for the power supply. If the amp powers up with the smaller fuses and they don't blow, check the speakers and the wiring (for shorts to ground or shorts between wires).
Nov 22, 2007 | Rockford Fosgate p-450.4 Car Audio...
201 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
