Question about Caterpillar D5g Xl Track Type Tractor By Norscot 55131
Catapliiar mechanic Parking break switch is coming on which completely stops my dozer we have replaced the park break switch it fixed it for 5 minutes then same thing , our local dealer told us it was speed sensors on the drives which are 240.00 ea please let me know if you can help 870-819-5454 stanwhittconstruction@yahoo.com
Break lights
The problem is that you pressed the pedal to the max when you installed the new switch. The switch is improperly adjusted. You should just have to loosen the mounting bolts on the switch, have someone watch the lights and adjust the switch so that the lights come on when the pedal is depressed about a quarter inch. That should fix the problem because your ABS and ESP systems monitor the brake light switch and when it comes on so if it doesn't come on or stays on it messes up both of those systems.
Jan 18, 2014 | 2005 Audi A8
Parking brake light is on and brake feels stuck
It most likely has one or more frozen brake calipers (very common)I suggest replacing them in pairs, Make sure you flush the old brake fluid out.Check the E-Brake cables to make sure they move freely.The light coming on could be low fluid level.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_a0891ab86974ea74
Jan 10, 2012 | 2000 Oldsmobile Intrigue
Why does the parking break light stay on in my 97 Olds Cutlas Supreme. I have checked the level of the break fluid and it is full. I did have new break lines put in last year. I did have to slam on my...
Apply the parking brake with the vehicle parked, engine turned off and transmission in Park. Release the parking brake completely, then apply it again, and ensure that it is fully released. Turn the ignition on, check to see if the Parking brake warning light is on. If it is NOT on, apply the parking brake and check to see if the warning light comes on. If the light come ON wihen the Parking brake is applied,.....fully release the parking brake and check if the warning light goes OFF. If it does NOT go off, then an adjustment is needed at the parking brake switch.
Jan 09, 2011 | 1992 Oldsmobile Cutlass Supreme
Because of noise from the left rear wheel of my 1991 Merc SEL420, the mechanic took out the parking brake assembly which was broken and the cause of the noise. I do not use the car much but now would like...
YOU NEED A 91 MERCEDES REPAIR MANUAL LOOK AT BRAKE ASSEMBLY IT WILL HAVE PARKING BRAKE ASSEMBLY.GO TO AUTO ZONE BUY REPAIR MANUAL IT HAS PHOTOS WITH PARKING BRAKE ASSEMBLY.
Mar 25, 2010 | 1991 Mercedes-Benz 420
ABS and Parking Break dash indicator lights stay on
I HAVE SEEN A BAD BRAKE LIGHT SWITCH.CAUSE THE ABS LIGHT AND BRAKE LIGHT COME ON.WHEN SWITCH WAS REPLACE BOTH LIGHTS WENT OFF.
Jul 22, 2009 | 2001 Ford Windstar
2000 ford expedition emergancy brake keeps not working. I get it fixed and a couple of weeks later it isn't working again. Mechanic says t has something to do with the cable keeps coming out of it's track....
I checked for a TSB and there isn't one for this issue. I have not heard of it either. If it were mine, I just wouldn't use it. Which cable? Ay park brake or under body?
Item Part Number Description 1 2780 Parking brake control 2 2783 Remote release lever 3 2A635 Parking brake rear cable and conduit — (RH) 4 2A635 Parking brake rear cable and conduit — (LH) 5 2A602 Parking brake cable equalizer 6 2853 Front parking brake cable and conduit
Jun 24, 2009 | 2000 Ford Expedition
Parking break light is on & Chimming When P. Break is released
On your parking brake assembly is a single wire switch. You can unplug it, but you will have to remember not to drive with it set. To replace the switch the whole assembly will have to come out. The switch is about $20 and labor should run about two hours. Good Luck
May 20, 2009 | 2003 Chevrolet Suburban 1500
93 Honda accord - idle real low (500 rpm) HELP, please!!
near the throttle body there is an adjusting screw(flat head) for air fuel mixture, it's on a deep cavity sometimes with a cover, adjust counterclockwise will increase the idle.
May 07, 2009 | GMC Canyon Cars & Trucks
Caterpillar D5g Xl Track Type Tractor By Norscot 55131 Logo
81 people viewed this question
Top Caterpillar Toys Experts
fordexpert
DROPNDEAL
DROPNDEAL
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
