Spin cycle does not work - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
Possible that there is power to the motor when the program comes to the spin mode. You need to confirm this with a voltage check when the cycle moves to SPIN. If so the fault lies with the program controller unit. There can be failure in this output.
Posted on Jan 10, 2013
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
The Spin Cycle does not work
Suspect that the Timer module is faulty as it does not move automatically to the SPIN mode.
You need to try with another program cycle to confirm or otherwise replacement is the only option. check on cost and options..
Jan 16, 2013 | Washing Machines
This is for a Whirlpool washer and dryer thin stack. All four of the wash cycles work AND all four of the spin cycles work, but the rinse cycles do not work. I have to manually skip it forward past the...
I would suspect the water inlet valve as being the problem,if it drains the water and spins the lid switch is going to be good.The thing exclusive to rinse cycles is that they only fill with cold water,and that is what i suspect the problem being is that it's not filling with cold water on the rinse cycle because of a bad water inlet valve.
GENE
Sep 12, 2011 | Washing Machines
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
