Question about HP VM114UA notebook
HP laptop screen is black
Screen is black and images really not visible
  • HP Master
  • 27,725 Answers
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Posted on Jan 09, 2013
  • 359 Answers
SOURCE: Why did my HP Pavilion ze2000 screen go black?
john79:
I know that you had a chat about this matter, and I hope that your issue was solved. However, I had made a note of it when I saw the chat go through. I was unable to help at that time, but remembered having seen something of this nature and wanted to follow through on it.
Although the ze2000 is not listed, other 2000 models are listed in the following link as defective - and recognized as such by HP - with this very specific defect. (Please see http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&product=18703&docname=c01087194.)
Again, if your issue has already been solved, congratulations. Otherwise, I hope that the information provided here will be of use to you, either in fixing the equipment problem yourself (perhaps with a BIOS update) or by convincing HP to do something about it. At least you would be armed with good solid documentation of their recognized issue!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 26, 2008
simard2
  • 124 Answers
SOURCE: HP Pavilion Dv6700 black screen after booting up
Go to the following HP website to view the problem and how to fix it:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=us&product=3636595&rule=21826
Hope you see what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
Posted on Jan 30, 2009
benwabnick
  • 2404 Answers
SOURCE: Barely able to see screen.
Your screen or the inverter underneath it which controls the power to the screen is bad.
Posted on Feb 04, 2009
mailtoravi
  • 186 Answers
SOURCE: HP Laptop Pavilion 2000 is on but screen is black
If you are using a AMD based Notebook, this may be one of the simptoms identified by HP earlier.
So, if your notebook is having AMD Processor, I recommend you to get the Product Number of the Notebook and check if it is listed in the weblink below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01300427
If yes and if your Notebook is less than 2 years old, you can contact HP Support and find the options to get a free repair.
Unfortunately, if your Notebook is equipped with Intel Processor, all you need to do is check the warranty and contact nearest Authorized Service center if the Notebook is out of warranty or contact HP for options.
Posted on Mar 07, 2009
  • 56 Answers
SOURCE: My HP Pavillion dv 6000 series laptop dislay issues
u have to replace the screen
Posted on Aug 16, 2009
Screen has lines
More than likely the screen. The inverter normally causes things on the desktop to be barely visible. The whole screen looks black, but with a flashlight you can see the images are there when the inverter is bad.
Mar 22, 2012 | Toshiba Computers & Internet
Blotted screen in my hp laptop
1.Locate the problem pixel. Display a true black image on your HP's monitor. You can do this by playing a DVD on your HP laptop, and pausing it on the black screen just before the movie starts. Once you bring up a black image on screen, the stuck or dead pixel should be visible.
2.Try applying direct pressure to the problematic pixel. After you've located it, turn off your laptop. Place a soft cloth or rag over the pixel to avoid damaging your screen. A soft chamois works well. Using the tip of a pen, apply gentle pressure to the pixel. You don't need to press hard, as too much pressure can crack or scratch your screen. While applying pressure, boot up your laptop. This should force the pixel to begin working properly.
3.Tap the pixel. With your Toshiba booted up and an image on the screen, gently tap the pixel with the rounded end of a pen cap. Tap hard just hard enough to see a small white flash on the screen. Tap your HP's screen until the pixel begins working properly.
4.Download a stuck pixel program. Several programs, including JScreenFix, UDPix and Pixel Protector, are available for download and can help fix a malfunctioning pixel. These programs display rapidly changing colors and images on your screen. The flashing colors and images can force the pixel to begin functioning properly.
5.Contact HP. If none of the above methods work, your screen may have a pixel that is truly dead. If that's the case, the only option is to replace the display completely. Contact HP customer support at www.hp.com to find an authorized repair service near you.
Sep 19, 2011 | Computers & Internet
I thin k I am having back ilight and/or inverter program with my HP dv6275us Notebook based on the following: - machine powers on but o video or image on screen or image is extremely faint. Upon closer...
These are typical symptoms of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
As for the cost, I would suggest a search on ebay.com
Sep 06, 2010 | HP Pavilion dv6275us (RP284UA#ABA) PC...
HP Pavalian laptop screen gone black and blank.
It seems like the lcd back light may have failed can you see a faint image on the screen when you look really close, try it with a torch. If you dont see even the faintest image the inverter has failed and needs to be replaced. If you look on youtube again and search for videos of replacing both the back light and the inverter it will give you some info on how to change them. Do a google search for hp spares and you will probably find what you are looking, i think the inverter is about £30 and the back light is bit cheaper. hope this helps.
Feb 11, 2010 | Computers & Internet
Screen doesn't come on immediately. Have to press
Checkout your poota power setup configs, just could a malfuction or wrong data entry
If you are talking "New" with a year, take back to point of purchsed with proof of purchase and give them the problem, you want to be online?
Nov 14, 2009 | HP Pavilion dv1000 Notebook
My Compaq Presario v2000 will turn on but the screen is just black what do I need to do to fix it?
Can you see any image on the screen in a dark room, using a flashlight sometimes helps. An image will be most visible right after you turn the laptop on, when the logo appears. If you can see the image but it is dark you need a new probably backlight inverter which is a relatively easy and cheap repair - I usually charge less than $50. JC Hunter
Nov 13, 2009 | HP Compaq Presario V2000 Notebook
Feb 04, 2009 | HP Compaq Presario V2000 Notebook
Jan 30, 2009 | HP Pavilion dv6000z Notebook
HP VM114UA notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
