Question about Dometic Rooftop RV Air Conditioner
Gas furnace does not come on
I have a Dometic duo-therm comfort control T-stat, gas furnace below, and one roofftop A/C unit. Until recently, i couldn't get anything to come on, but when i went up top and opened the A/C lid and got into the power module board/control box to check voltages, now the fan and A/C works, but the furnace will not. I checked to see if DC power is getting to the furnace and confirmed that. Any thought at what it could be before i take it in??
  • Dometic Master
  • 6,674 Answers
You should have 2 blue wires as well down at furnace connections. Remove thermostat wires going to those 2 blue wires and connect those 2 blue wires together, ( make sure they don't touch anything else) with thermostat on heat setting. If 12 VDC power going to red & white or red and black at furnace, connecting those 2 blue together, should start furnace. If not problem at furnace, if it does start, problem at thermostat or wiring to it. All that does is by-pass thermostat to confirm where problem is.
Posted on Jan 27, 2013
I have a duo therm ac unit on 2003 gbm f53 fan only works in the on position not in the auto also unit will not shut at stat only with breaker any clue
First you may check the t-stat settings if its a digital tstat. Some t-stats need to be "set up" for your unit. The configuration of the t stat may be for a gas furnace (which controls its own blower) and you may need it to be configured for an electric (heat&cool) unit which the t-stat controls the blower operation. As for the non stop operation that could be a normally open switching relay that is stuck closed. Or numerous other situations. Can't help much there.
May 29, 2015 | Heating & Cooling
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Furnace fault codes ignition lockout fault.. and this means what?
This means the furnace will not operate. Remove the power and then on again to clear it.
Sep 30, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Flashing code ee
sounds like defective t-stat or it needs to have time and setpoints reconfigured
Sep 18, 2013 | Dometic 3109228.001 Duo Therm Comfort...
Furnace refuses to cycle off even when room is 20 degrees warmer than setting
Do you know how to access your furnace wiring ? What make/model furnace?
Jan 18, 2013 | Dometic 3109228.001 Duo Therm Comfort...
My dometic duo-therm thermostat is no longer showing an option for my furnace.
I assume it's remote control. (comfort control) Have you tried following procedure for selecting "Mode"?
Nov 06, 2010 | Dometic Rooftop RV Air Conditioner
Crazy Heat
I think that I would change out the thermostat only due to the symptoms you are describing. Think the control board may be fine however, the thermostat sounds as if the internal componants are going out. Good luck on your repairs
Dave
Sep 22, 2009 | Dometic Rooftop RV Air Conditioner
No 12 volt power to duo therm comfort control box
check if you have 240V and then 12V to the secondary of the transformer if none then its your transformer that is faulty
Aug 02, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
201 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
