Philips tv 60pl9220d/37 flashing red and blue light on power button
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
This is a fault code. You must look for it in its repair manual. Check this, and see whether it can help you. There is detail about how to count these blinking, and convert them into code. This blinking code will help you to locate the faulty section circuit board inside it.
Posted on Jan 10, 2013
  • 52 Answers
SOURCE: philips tv error code
1 long and 4 short blinks for this model is specific to class d audio amplifier on small signal board. if it is intermittent where this sometimes happens and you can unplug and replug and power back on would be related to the firmware version but if version is correct you would still need to replace ssb
Posted on Aug 17, 2008
Xeuvious
  • 100 Answers
SOURCE: tv turns off and I get a red flashing light on
After looking through the user manual I could not find any error codes to diagnose your problem. I suggest calling Phillips Customer Support at 1-888-PHILLIPS.
Posted on Sep 30, 2009
SOURCE: 42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Posted on Jan 24, 2010
Testimonial: "Thank you for your help, I will give it a shot!"
  • 8457 Answers
SOURCE: How do you replace the
Go to website like Youtube.com.Type in ur DLP tv make and model.U will have a tutoring video by some body doing the projection lamp bulb replacement.
Posted on Nov 15, 2010
  • 368 Answers
SOURCE: I have a philips 60pl9220d/37,
It means your tv is over heating, the bulb. In this case you are most likely to buy a new bulb soon as the bulb is heading into the end of it life.
Posted on May 24, 2011
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
I have a philips 60pl9220d/37, and when I turn the power on there's a red light i'n the middle of the blue circle and was wondering what it ment and what caused it.
Apr 24, 2011 | Philips Televison & Video
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Bottom left lights. when i turn on tv red light flashes what does mean
bottom left lights. when i turn on tv red light flashes what does mean
Jan 02, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Apr 15, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Red light flashing on tv
My 37" TV Will not yurn on . The green light goes on for 2 seconds then goes off and red light starts flashing. What Repair/Part is needed.
Aug 31, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Electro Med Services...
