Question about Fein 9-55-13 Turbo II Bagged Canister Vacuum
Cracked lid/top of fein vac model 9-55-13
The lid to which the handle is attached is badly cracked. Can this part be replaced? I can not find anything as far as a parts listing online for fein to reference. Can you help me out? Thanks
    Problem Solver:
  • 6 Answers
Contact Rudi at E & H Repair in Chicago. They are an Authorized Warranty Repair Center for Fein. The phone no. is 312-829-6770. Email is rudi@kooltools.com. Good luck
Posted on Mar 23, 2009
I used West System 105 resin with hardner and high density filler. Mixed it up and spread it around the break. Works fine and that was a couple of years ago. However, my Fein vac has started howling so much that it can be heard a block away. Figured it had a bad bearing. Opened it up and finally got the motor out but for the life of me I can not figure out how to gain access to the bearings. Must have them but I can not get to them. Anyone else had this problem.
Posted on Jun 20, 2009
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
Need switch for Fein mdl 9355.13 vac. Where to purchase?
Type www.fein.com in the address line in browser. It should take you to Fein in your country. On the left hand side of screen you will see a list of links click on service then Authorized workshops that will give you a list of places to fine spare parts and repairers.
Mar 26, 2012 | Fein 9-55-13 Turbo II Bagged Canister...
I need the orange top cover for my 9.55.13 because mine is cracked. Where can I buy one?
You will probably be able to find it at: http://www.ereplacementparts.com/fein-parts-c-15741.html?osCsid=2cldhjbhfcq03503il7el658t4
Paul
Oct 12, 2010 | Fein 9-55-13 Turbo II Bagged Canister...
I can't keep the attachments from falling off while in use. I suspect I need new hardware, but cannot find instruction for Fein msx 636 II
Are you fully opening the lock lever when you are putting the attachments on? If you are new to the machine, you need to fully open the locking lever on top, insert the attachment and be sure it "seats" in the shaft holder and then close the locking lever and be sure it is tight.
Sep 14, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Motor died
Hi
Yes you could order a replacement ..BUT.. you will need the right tools.
Also the wiring is not that simple... you will have to know the wiring color codes....
It is usually NOT a good idea to do this yourself unless you know a little of mechanics and electronics.
Regards
Berry
Feb 07, 2010 | Vacuums
I have a Vacu Queen V3000 and it stopped working in the middle of a job. I verified that I have power at the outlet that it plugs into and then checked motor resistance from the plug and I got about 600...
As a quick test Plug in the vac again and turn on the switch, then try your power head. If the head works you have a motor problem, if the head doesn't you likely have a cord problem.
You seem to be saying it failed while running??? which generally indicates your switch is the suspect.
Check the motor for a worn or sticking carbon brush.
Motor is access by removing the chrome lid and 3 screws under the handle., then removing the paper cone and unscrewing the center screw a t he bottom of the plastic.cone cage...
Dec 12, 2009 | Filter Queen Majestic Canister Vacuum
Model number U5763900 Serial Number 090400013588 Handle broke off just above the four screws that attach it ti the boby of the vac. Hoover does not list parts for models that are more than two years old....
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=658103
Generic problem for all Vacuums
Posted by rlholif on Jun 09, 2008
Model number U5763-900 Serial Number 090400013588
Handle broke off just above the four screws that attach it to the body of the vac. Hoover does not list parts for models that are more than two years old. The vac operates perfectly but without a handle my wife cannot use it, where can I find a part replacement. Easy to remove four screws and replace. Don’t want to drive 100 or more miles to find an authorized repair shop. Oh yes, this is a Hoover Preferred Wind Tunnel Bagless
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You have all the information needed but I would contact your local vacuum cleaner dealer and they may have a good used one or they may stock a new handle for your you or they can ship you one If you live too far from a factory authorized dealer. The vac shop that I worked in always had good used parts for ½ the price and it worked just fine – the only difference was the color and for the handle that would not make a difference in the performance and your wife could use the vacuum again. Also Hoover can ship the part to you providing they have it in stock. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Vacuums
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Fein 9-55-13 Turbo II Bagged Canister Vacuum Logo
341 people viewed this question
Top Fein Vacuums Experts
Bill Boyd
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
