Dryers Logo
Posted on Jan 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Long dry time - Dryers
Bill Eager
Level 3:
  • Master 460 Answers
  • Posted on Jan 09, 2013
Bill Eager
Master
Level 3:
Answers
460
Questions
6
Helped
119136
Points
1216
Check you vent for clog
How to change time settings on a Kenmore series 600 electric dryer
Follow these simple steps:
  1. Turn on the dryer by pressing the "Power" or "Start" button.
  2. Use the "Time Dry" or "Timed Dry" button to select the desired drying time. Press it repeatedly to increase the time in one-minute increments or hold it down to scroll through the time options more quickly.
  3. Once you've set the desired drying time, press the "Start" button to begin the drying cycle with the new time settings.
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Whirlpool Dryer GEW9200LW1 skip digits when set to dry
If the clothing comes out dry within a normal time,usually 40 minutes or less. Whats happening is the computer is recatulacting the time remaining to dry a load of clothes as it senses they may still not completly dry or even will drop off some time if clotes are dry before time computer calculated at start of cycle.
Gene
Amana ned5100tq0 drys when set to timed dry but will not dry in automatic setting
Mines the exact opposite. Slowly it started stopping while the timer kept going for times dry. Now it won't run at all on times dry but the timer still moves. It also won't run for air dry.
1helpful
AUTO CYCLE TAKES A VERY LONG TIME, HEAT IS OK, GAS DRYER
First thing I would check is the vent. If you have good heat but it is still taking too long, usually it is caused by a vent that is either too long , kinked or clogged. if the dryer is auto dry and not electronic dry then you will need to gauge weather the load needs more or less dry. If it is just taking a long time for the clothes to dry, more than likely the vent. If the clothes are dry before it is done running then it is more than likely a setting issue. Way out of the box .... are your clothes spinning out dry enough in your washer? do they dry in the normal time on timed dry?
Dec 18, 2009 • Dryers
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
2answers
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
What is the best setting to dry jeans on a kenmore 9000 electric
Use Auto Dry for most things and vary the "dryness" level to more or less depending on the thickness of the material you are drying. Auto is most efficient and will adjust itself for finish time.
Auto dry and select "more dry" before hitting start, for jeans or towels.
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 • Dryers
Top Dryers Experts
john h
