Question about Xerox Office Equipment & Supplies
I have a Xerox fax model 745 with a error 41. When you turn the machine on it comes to ready but when you try to pprint a report or make a copy this error comes up in the display
  • 22 Answers
SOURCE: Brother IntelliFax 4100 sending solid black pages
There are two possible solutions. Is the machine sitting on top of metal? The machine will send black pages when there is static charge. You can put a rubber mat under the machine or use a static guard. The second solution is to put the machine in maintenance and reset the scanner. Unplug the machine, put your finger on the menu key first and then re-plug the line while holding the menu key, in about 30 seconds all the lights will flash and the display will say maintenance. Release the menu Key and press 55 and this will reset the scanner; if scanner error comes up the machine will need to be serviced. Press stop and then 99 this will exit you out of maintenance. If the machine does not have an error try making a copy of blank sheet of paper and see if there is any improvement. As a routine clean the scanner glass with soft lint free cloth and isopropyl alcohol also.
Posted on Oct 05, 2007
  • 208 Answers
SOURCE: Power Failure message
What is it telling you is that it was unpluged or lost power for a short period of time.
First of all just try pressing the Stop Button.
The try powering it off with the power switch. Remove the power cord for a minute then replace the plug and turn on.
That should clear it.
Anoying message, but just an indication that you lost power unexpectedly.
Posted on Dec 13, 2007
bowdo
  • 78 Answers
It sounds like the CIS (scanner) has failed in both machines. Its no generally not a common problem. I would change one every six months if I was lucky.
It may point to something in your environment. I have have seen rust build up on the contacts of the scanner cause this problem. So if you have high moisture or are close to the ocean this maybe a problem.
Posted on Feb 14, 2008
slipnoman
  • 53 Answers
SOURCE: NEED ERROR CODE TRANSLATION
I do not know what the error code means but try this http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
They should be able to fix your problem
Posted on Jan 09, 2009
  • 215 Answers
SOURCE: display says "printing online" but it is not connected to a PC
unplug machine, press and hold down the "stop/exit" key while pluggung back in. continue to hold the button down for 5 secs, then release. if machine returns to the regular date/time display, you should be alright. if not, then you'll have to call brother or an authorized service center. this is usually caused by a fax stuck in memory, which this procedure should clear.
good luck,
razors
Posted on Feb 18, 2009
Pls machin off
Now press & hold 2 minutes 4no button+power saver button+stop button press and then machin on showing hdd formet after some time ready to copy your machin
Aug 21, 2014 | Xerox WorkCentre 5325 5330 5335 Black...
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Copy report after sending fax
it will be under reports, you can set all faxes to do a report after a fax has been sent, ill keep the terminology easy as
Brother, canon, konica blah blah all uses different terminology for it, but there is a setting in reports for user that they can turn on, it like error reporting if a fax deosnt go it will print out a error report so same thing to do with copy report.
regards
Fax Tech
Apr 01, 2009 | Office Equipment & Supplies
Can receive a fax, but cannot send fax.
I was told by Xerox support tech that he thought it was the fact that we do not have a dedicated analog phone line, but the fact remains we can receive faxes but cannot send them. The only fax that will send is directly to Xerox support.???. The machine was working fine, faxing (sending and receiving), until about a week or so ago, when we had a repairman here on the printer. He told me to report the problem to our telephone repair service. He is coming out today! I'll let you know.
Feb 19, 2009 | Xerox Phaser 6115MFP/N Laser Printer
Xerox Phaser 6110MFP reports FM_IO.c 172 ROOT during startup
Also make sure you have the machine plugged directly into the wall outlet...some surge protectors or multi-outlet strips won't allow sufficient power to properly boot up and run the machine !
Dec 10, 2008 | Xerox Phaser 6110 Laser Printer
All copies are blank
What happens when you print a report? Do you get print then? If you can print reports and then you get blank copies the problem is your scanner. If you can't print or copy, then the problem is in either the drum, I would say 30 percent, or laser probably 70 percent.
But we have to find out if it will print a report. Do you use the machine as a fax ? Do they print ok?
Sep 29, 2008 | Xerox WorkCentre M15i Laser Printer
Xerox ducu centre 420dc wonte come to ready. no error code turn it off and on clears sometimes but takes a lot of trys
When the machine comes on. There is a cable that runs from the scanner to the processor. When the machine is ON, unplug it and re connect it . It should reboot. That cable most likely needs replaced. But try disconnecting and reconnecting it with the machine on.
Jul 29, 2008 | Xerox Office Equipment & Supplies
Error message on Xerox workcentre 7242, error 010-333
Fuser jam, maybe the exit switch ?
If you turn the unit off and back on does it come up ready to copy or ready to scan you job
Jul 07, 2008 | Xerox Office Equipment & Supplies
Xerox work center pro 657 comes up " memory is full" no faxes are coming in or out
NOTE:A User RAM Clear will clear the Activity Report, Error counters, and any documents in memory.
  1. Power OFF the machine. The power switch is located on the left side of the machine, toward the back, next to the Copy Output Tray.
  2. Press and hold down the [*] and [#] buttons on the Control Panel at the same time, while powering ON the machine.
  3. Release the buttons. The machine will warm-up and return to Standby mode. Memory in the display will indicate 100%.
Apr 14, 2008 | Office Equipment & Supplies
79 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
