Question about Canon PowerShot SD1000 Digital Camera
Camera says "Memory Card Full" but the card is empty...
I got my camera today and charged the battery all the way and put everything in the camera. I did a test movie just to experiment with it and took a 15 second video, and then deleted it, and now it says the memory card is full. but it's not! I don't understand. Please help! Thanks
  • djwalker Jul 25, 2008
    memory full after 3 pictures. Something is not set right. the memory card id 16MB
    Scholar:
  • 35 Answers
Hi, First, lets try formatting the card. But be aware that it will erase everything on the card. 1 Turn on the camera 2 Press the Menu button 3 Toggle once to the left to get the Setup menu (the one with the hammer/wrench icon) 4 Toggle down to Format 5 Select OK and press the Set button. To perform a low-level format, press the up arrow and then the right arrow to add the check mark. After you do this, exit the menu by pressing the Menu button. Take some still photos first. Download them to the computer but don't delete them from the card yet. Disconnect the camera from the computer (or if you are using a card reader remove the card). Delete the images from the card by using the menu in the playback/review mode. Let me know if this solves anything.
Posted on Jul 02, 2007
2 Suggested Answers
SOURCE:
  • 19 Answers
SOURCE: Camera says "memory card full" and there is nothing on the card.
go into the camera's system menu and look for "format card" doing this will enable the camera to utilize the memory card. let me know if this helps, if not there are other things we can try.
Posted on Jul 05, 2007
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
Memory card is full and when I plug in the USB cord and turn on the camera I get a message that my device is not connected or is busy, or that it contains no pictures!!
Causes of memory card corruption
  • Turning off a camera before an image is completely written to the memory card.
  • Removing the memory card from a camera while an image is being written to the card.
  • Removing the card from a memory card reader while files are still being transferred to a computer.
  • Batteries conking out as files are being transfered directly from the camera to a computer. Note: always make sure you have fully charged batteries before transferring images.
  • Removing the card from a card reader while folders and files from the card are open on a computer.
  • Opening, deleting, renaming or moving files on the card while its contents are open on a computer.
  • Using a memory card which has not been formatted in the camera. Use the delete/erase function when needed, however a card should be regularly formatted.
  • Formatting a card in a computer instead of the camera.
  • Inserting a second memory card into a card reader before closing and removing the first when viewing images on the card from a computer.
  • Taking photos when camera batteries are nearly empty.
  • Taking photos too rapidly so the camera can not complete writing one image before starting the next.
  • Continually shooting and deleting, shooting and deleting images when the card is full.
  • Letting a memory card get too full before downloading the images to a computer or storage device. Cards that are too full may overwrite the card headers.
  • Using a memory card from one camera in a different camera without formatting it in the new camera first.
Feb 28, 2008 | Cameras
CAMERA SAYS INTERNAL MEMORY FULL. I PUT NEW CARD IN. STILL SAYS INTERNAL MEMORY FULL
The internal memory is the memory built into the camera, not the memory you put in with a memory card. This internal memory is rather small. If it is completely full, it will stop your camera working even with an empty memory card.
Take the card out of the camera, and delete some of the photos on the internal memory before you put it back in.
Nov 25, 2010 | Kodak Easyshare C190 12MP Digital Camera...
New camera ,not working.
lol, ok...The memory card will only go in one way. But check the little white switch on the side of the memory card and make sure it is NOT in the locked position. Once this is taken care of reinstall the memory card. Now in you options/menu screen you can select on there where you want your pictures to be stored...Device / Memory / Auto. You can either put it on Memory or Auto (if you have this). In addition, you may need to format your new memory card. This is also in your menu screen to Format Memory Card. Go ahead and do this. But be forwarned...if you do this when you have pictures on your card, it will erase all of your pictures completely. If you do those things, everything should work fine. You don't need a full charge for your camera to work, but if you have rechargable batteries, it is recommended to fully charge your camera before use. If you are using standard AA batteries this isn't necessary. Oh, and when your memory card is in the camera you should see a little icon on your LCD screen that looks like a mini memory card. This is an indicator that the camera recognizes you have the memory card in the camera and along with that will be a counter...ie 4/1200. The first number is the amount of pictures taken on the card currently and the second number is the total possible pictures you can take on the card before it is full.
Any further questions
extreme7528@yahoo.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 13, 2009 | Cameras
My Kodak af 3x optical aspheric lens camera won't turn on. it was fine yesterday but today it wont turn on. I've charged it and everything but it doesn't do anything. Help!
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Sep 24, 2009 | Cameras
Sanyo camera will not turn on battery is fully charged
First you check ur battery power still constant if not check ur memory card .Empty. ur memmory card through another card reader then on ur camera without putting MC.
in this way ur probleum will solved.
thanks.
May 11, 2008 | Cameras
Aiptek IS-DV
Try to format the card first
Dec 29, 2007 | Aiptek IS-DV Memory Card Camcorder
MEMORY CARD
I had the same problem today with a 2 GB card. I think it may be the size of the card. When I put in an old 32 MB card it worked fine.
Dec 26, 2007 | Vivitar ViviCam 3785 Digital Camera
Jul 01, 2007 | Canon PowerShot SD1000 Digital Camera
Camera still won't start...
hello, Dont worry lady, i think your problem is related to memory card. i suppose that you did not format memory card regularly, so format your memory card specific in your camera. and then try. i hope you deffinnately succeed. good luck...
Jul 30, 2006 | Olympus Camedia C-350 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
4,047 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
