Getting a "No Signal" message on the monitor - Computers & Internet
  • 54 Answers
Power of pc and monitor. Check the cables from your PC to your monitor. Power back on. If you have installed a new graphic card, reopen your pc and reseat the card (the pins might have lost contact).
Posted on Jan 09, 2013
Acer flat screen monitor
acer monitor v193hqv power supply regulater ic burn so iwant circuit or ic no part no ic 802 problem plse solution
May 03, 2013 | Acer S202HL LCD Monitor
How do i remove the no signal message on the upper left corner of the screen
The reason your getting that message on the screen is because the monitor is not recognizing a video signal from the computer. Make sure your hooking up the monitor to a working computer because then when you go to turn on the computer the message will go away on the monitor.
If you know your computer is working and the message doesnt go away then its an issue with the main board inside of the monitor and since no parts are available for that, you would have to get the monitor replaced.
Sep 30, 2010 | Dell IN1910N 19" Monitor
Signal cable not connected
what do you mean? You are getting that message when you switch on? Have you checked the signal cable between your PC and your monitor? If you cable is connected properly and you are still getting that onscreen message, it means your monitor main board has failed, and if its out of warranty, its time to get a new one, because few repair shops will touch them, and when they do, it is not cheap.
Jun 18, 2010 | BenQ FP567s 15" LCD Monitor
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
No signal message on monitor.
try to check your vga cable..try it with another one..
May 11, 2010 | HP w1907 LCD Monitor
SIGNAL OUT OF RANGE MESSAGE
Sounds like your PC has changed resolution to one not compatible with your monitor. Try to boot in safe mode to change the resolution to more basic. Then reboot.
Monitor Mike
Apr 24, 2010 | Optiquest Computers & Internet
Power save mode
Yes, you arent getting a signal to your monitor from your video card. Try replacing. If its onboard then the Mainboard may be bad. These machines are known by Dell to go bad and is covered under warranty, provided you still have it.
The message you are getting is coming from the monitor, not the P.C.
Its telling you you it went into power save since its not getting a video signal from the P.C. Check connections as well.
If your using any kind of splitter, remove it and connect monitor directly to P.C. to be sure.
Good luck
Nov 28, 2008 | Dell OptiPlex GX280 PC Desktop
Monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
Sep 25, 2008 | Compaq TFT5015 15" LCD Monitor
Problem
hmm,
Exact message could Find a Closest solution.
anyways, what you might be getting is a message like,
No Input signal,Check Video Cable.
it means that the Connection from the Monitor to PC is Loose,
Connect them Secure and tight to FIx it.
Jul 16, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
