Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Where is drain plug on john deere 322 - John Deere 420,1020,2010,2020,2510,2520 Tractor Float
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
snowghost1
  • 784 Answers
SOURCE: 322 John Deere Overheating. New
one thing that you did not list in your list of replacements that could be the cause of your over heat problem is the thermostat.
relace the thermostat.
now as far as the full strength antifreeze goes, it all depends on what part of the world you live in ( hot or cold ). since you will need to drain part of the antifreeze to replace the thermostat - when you go to refill the radiator use a 50/50 mix and you should be pretty close to the correct ratio.
c...
Posted on Jan 04, 2011
  • 5 Answers
SOURCE: where is the drain plug
There should be a pipe type plug in the bottom of the transmission housing near the draw bar inline with the rear axle housings. Whether you have a hydrostatic drive or gear drive, the plug is in the same place. Reference # six in drawing.
Posted on Feb 17, 2011
philwalker78
  • 608 Answers
SOURCE: where do i check the trans fluid on a 15.5 hp John
Hi, the unit is a sealed type, you cannot change or check the fluid level. Hope this helps, regards Phil.
Posted on Jul 18, 2011
  • 100 Answers
SOURCE: Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
Where can i find the oil drain plug on kt17 kohler motor
look for a pipe that has a plug in the end or a pipe cap .
Oct 04, 2017 | John Deere Garden
How to drain the fluid on a 550 john deere dozer
Put on your old cloths and crawl under it . Remove the drain plug and catch the oil in a container If it has a guard plate underneath there should be a hole with a removable plug in it If it is the radiator you want drained there should be a plug or tap under the bottom of the radiator and a plug on the side of the engine block
Oct 18, 2015 | John Deere Garden
What is the size of the four front hydraulic ports
Services and Support from John Deere
https://www.deere.com/en...support/services_support.page
John DeereGet the latest on services and support options from John Deere.
Oct 15, 2015 | John Deere Service Repair Manual for 322...
How can i get a wiring diagram for john deere 322
Here's the link and I'm sure you will get the solution of your problem.
john deere 322
Oct 03, 2015 | John Deere Garden
Got new brakes and now the hubs won't turn
You need to adjust the slack adjusters
Jan 31, 2013 | John Deere Garden
322 John Deere Overheating. New rad, hose, rad cap. No noise or leaking from water pump, however I may have put full strength coolant in it. Thank you
c...
Jan 04, 2011 | John Deere Garden
Engine turns over and getting fuel, put has no spark on JD 322
check for cracks in the spark plug wire it sounds like it is shortening out or a ground wire.
Mar 01, 2010 | John Deere &Reg Branded 27" Tractor Metal...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
43 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
