Question about Sanyo SR-3770S Counter-High Refrigerator Black and Stainless-Steel
Refrigerator Sanyo 3770s stopped - Sanyo SR-3770S Counter-High Refrigerator Black and Stainless-Steel
Power is not working? how can i do?
Check input power supply and pre-fuse .hope problem will solve
Jul 20, 2016 | Sanyo Sr-a2480m 2-2/5-cubic-foot Compact...
I want to remove the freezer tray from SR-2570M. Can this be done without removing the refrigerant?
No. The freezer "tray" is the evaporator, and therefore, the most important part of the unit. (this applies to most mini-fridges out there)
Mar 23, 2016 | Sanyo Sr-2570M Refrigerators & Freezers
What is cubic feet of sanyo sr-366w
mesure the inside of the refrigerator wxhxd = q" then multiply q" by 1728 = q'
Jul 26, 2014 | Sanyo SR-366W Undercounter...
What type of a compressor that the sanyo SR - 36A uses? and can it work if remove a 110v compressor and replace it with a 240v compressor?
You can use a 220 volt compressor, just make sure the evaporator fan is also 220 volts as well as all of the bulbs, and anything else that is 120 volts. Everything must be 220 volts. including the start and run capicitors.
Good luck,
Marty
May 11, 2014 | Sanyo Counter Height, 3.6 Cubic....
The freezer just stopped working. HELP!
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 23, 2011 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezer has stopped freezing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 26, 2011 | Haier 20.5 cu. ft. / 580 liter Upright...
Our freezer stopped freezing model fcm7drawn
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 12, 2010 | GE 7 cu. ft. Chest Freezer FCM7DR
Freezer stopped working suddenly
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 30, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Sanyo SR-3770S Counter-High Refrigerator Black and Stainless-Steel Logo
14 people viewed this question
Top Sanyo Freezers Experts
Jay Finke
Jay Finke
ray gallant
AJMAL KHAN
Are you a Sanyo Freezer Expert? Answer questions, earn points and help others
