Need antenna
SOURCE: New Delphi installation over older delphi car kit
Just installed the xpress RC in my Durango, replacing my SKYFi2. Both units are Delphi (all of the newer xpress RC's are made by Audiovox now, but Amazon sent me the Delphi made unit). Everything swapped out with the exception of the 12dc power cord. Had to use the one included in the new unit, plug size that goes in the new cradle for the RC is different. In the new unit I did get two "user guides" in Spanish and none in English (I wish America would adopt one friggin standard language. English) but other than that it was quick and painless.
SOURCE: delphi skyfi won't connect to my fm radio automatically.
The audio plug overrides the FM frequency setting. That way if you use a tape adapter to run the music through it will use that source instead.
A lot of FM channels are getting crowded into a lot of markets out there. The best way to fix the problem is to use a direct FM module. This way your Sirius will override the FM channel whether it is used or not.
Here is a link for one:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1998401&catParentID=7872&scId=7872&oldParentID=7872
they are very easy to install.
SOURCE: Delphi SA10001 XM SKYFi Boombox does not power up?
Did you try putting batteries in it and seeing if it powers up then? Also you could try a different power supply.
SOURCE: Antenna problem
yes, most likely. What about putting the MyFi in the 'base' with a regular antenna?
SOURCE: Need a manual
I would try the XM Radio DOT Com website and search for user manuals. It is relatively easy - a 3 on a scale of 1-5 to do.
