Question about Apple Computers & Internet
I want to change my monitor colour temperature
I would like to look at some wood stains on my monitor. I was recommended to change my monitor colour temperature to 6500K. How do I do this?
  • Apple Expert
  • 64 Answers
Go to "Settings", "Displays" then select the tab for "Colour". Now click the "Calibrate" button and follow the steps on screen.
Posted on Mar 24, 2014
How to prepare new knotty pine to accept a semi transparent water based stain
Wally, New wood should not require any prep. Although a light sanding couldn't hurt, the wood will accept your stain. Try it on a piece of your leftover wood first.
Nov 29, 2014 | Min Maw Sumpro 75 1800 Watt...
Flicking panel on side of picture
Is a problem with the tcon board - change it and will turn on good conditions.
Good Luck!
Mar 23, 2014 | Sony BRAVIA KDL-46V5500 FULL HD...
How to stain wood veneer
You would need a stain that would penetrate the wood veneer. A good oil based stain should be able to penetrate all the way through. Lightly sand the face of the veneer with 220 grit or higher sand paper. I use a sanding block made out of rigid foam and sand by hand. You will need to keep the veneer wet with the stain until it penetrates. I would stain both sides of the veneer until it penetrates to the depth you desire and then wipe off any remaining stain. You may need to press the veneer until it dries thoroughly! Good luck.
Mar 21, 2014 | Crafts & Hobbies
When you use the Colors window to select colors for text or objects in a document, you can also assign a color profile to the document. Color profiles help ensure that the colors you see in the document onscreen match the colors in the document when it's printed or viewed on another computer.
To choose a color profile for a document:
  1. In your document, select the text or object whose color you want to change.
  2. Open the Colors window.
    In some applications, you can open the Colors window by choosing Format > Font > Show Colors or Format > Show Colors. In some applications, you can also click a button in the application's toolbar or a settings pane.
  3. Click the Color Sliders button.
  4. Choose a slider option from the pop-up menu.
  5. Drag the sliders or enter specific values to adjust the color.
  6. Click the colored box next to the pop-up menu and choose a profile from the list.
If you open your document and the colors appear in a different shade or hue than you expected, the application you're using might not recognize color profiles. Try using the generic color profiles instead.
In some cases, an application may not open documents that use non-generic color profiles.
You can create your own custom color profiles using ColorSync Utility. For more information, open ColorSync Utility and choose Help > ColorSync Utility Help.
Jan 08, 2013 | Apple Mac OS X 1063 Snow Leopard Family...
Is there a difference preserving the wine in metal or wooden rack?
Terracotta winestones are less affected by temperature changes and are the best choice for wine in your living room , but not to place in a sunny side of the room in a place where its more outside influence sunlight.
May 29, 2012 | Furniture
Colors not matching computer
It is possible your colour cartridge has cross contaminated the ink reservoirs. To check this take the colour cartridge out and turn it over to see the coloured pads. They should look red, dark blue, and orange ( the colours are actually Magenta, Cyan, and Yellow, but are concentrated). If any of the pads are pale or particularly green - change the cartridge.
If the colours look alright, your issue is probably that your monitor makes colour by emitting light frequencies so is bright, printed images make colour by absorbing light frequencies so will always be darker. There is always the issue of course that your monitor also has a colour "temperature" bias. Photo pros calibrate their monitors and printers to match.
Mar 25, 2012 | Canon PIXMA iP90v Printer
Loosing wood colour in exterior deck flooring, floor unused for6m
When I recoat my outside wooden seating I use Danish Oil and if the colour has faded I add a small amount of stain of a suitable colour. You could try it with the linseed oil but the Danish oil dries to a hard coating and will build up if several coats are used, allow time to dry between coats.
Regards
Alan Hood
ami-man
Apr 19, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
Oven top has stains that cannot be cleaned
If your oven is not a glasstop and is the colour WHITE there is a ceramic touch up you can buy, this paint is high temperature and can be used to cover chipped areas easily. the part number is 12W. If you do not want to paint over these stains I would try a heavy degreaser called spray nine. if your stains are caused by heat warping or changing the tops structure you may have a temperature issue.hope this helps.
Thanks
Oct 11, 2009 | Whirlpool Ovens
Screen colour error
Recommend to go to the color settings and change it to the use settings and adjust accordingly.
Oct 17, 2007 | ViewSonic VA1930WM LCD Monitor
Computers & Internet Logo
37 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
