Question about Dryers
My whirlpool dryer wed5840sw0 will not start. The timer does run when I press the door shut off switch and hit start but nothing else happens. Any help here?
Nothing happens when I press the start button but the timer is working when the door switch is enabled. Any suggestions?
rickzilla
  • 706 Answers
SOURCE: Whirlpool LER5644EQ2 Electric Dryer that won't start
Regarding model LER5644EQ2, here is a link to a parts website complete with an assembly drawing and parts list. In all probability,you have a blown thermal fuse and that will need replacing http://www.pcappliancerepair.com/model-display.php
Item #23 on the drawing .. a quick test would be to ( with power removed or disabled) measure the resistance across the two terminals and it should not be an open circuit or it is blown. The drawing shows exactly where it is and the parts list shows the item number/ cost and where to buy a replacement. Hope this helps..
Regarding model number is YLEQ5000PW1, you may have the same problem with your thermal fuse.. the parts website does not show a detailed darwing of your model but it should be similar to the other one I've cited in the location and thermal fuse.. The link I am sending is for the parts list for your washer and the thermal fuse.. http://www.pcappliancerepair.com/model-display.php
Let me know if that isn't the problem and we can look at other ways to zero in on a solution..
Hope this helps...
Regards...
Posted on Sep 11, 2008
docjohn174
  • 943 Answers
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Posted on Sep 13, 2008
SOURCE: Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Posted on Jan 03, 2009
  • 13 Answers
SOURCE: WHIRLPOOL DRYER WON'T START
Test the door switch.
Posted on Feb 24, 2009
  • 686 Answers
SOURCE: Kitchen aid electric dryer won't start. The door
change your thermal fuse
Posted on Mar 12, 2009
Whirlpool wed5840sw0 dryer NOT STARTING
not make for large blanket change the white fuse air not going out
Nov 13, 2017 | Whirlpool GEW9250 Electric Dryer
My GEQ9800 dryer will not start. Start relay switch is good, timer is good, thermal fuse is good, door switch is good, input power is good. Nothing happens when you hit the start switch.
Is it plugged in. Seriously,
what about the heating element, have you tested it?
here is a link to replace it if it's bad
http://www.ehow.com/how_2240320_change-heating-element-dryer.html
Sep 30, 2011 | Whirlpool Dryers
Hit start button but dryer will not start can hear the timer running
Open the dryer door and press the door switch , to make sure you hear a distinct " click " . If the door switch seems ok , then remove the rear dryer panel ( UNPLUG DRYER FIRST ) . On the blower housing , you will see a white 1" long piece ( thermal fuse ) with 2 wires plugged onto it . This is the piece you need to replace . #3392519 is the Whirlpool part number .
Apr 18, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
110 people viewed this question
Top Dryers Experts
