Question about HP Pavilion dv3z Entertainment Notebook
My HP Pavilion dv3 won't wake up.
If I get the chance... I power down correctly. However, this pc is very subtle in it's warning about low battery level. There is an almost inaudible "ping", once, and a small warming image goes on in the bottom corner. (My old pc had a message that came up center screen -- impossible to miss.) Anyway, because of this, my laptop sometimes "dies" from low battery without being shut down properly. Also, recently I changed the "close lid" option to SLEEP. Laptop usually comes right back on... but I read on another post that the sleep option stressed the hard drive somehow. (Myth or truth?) This time I left my laptop to go to the bathroom and when I came back the screen was black/blank like it was hibernating or sleeping. Other lights on. Screen does not relight. Hmmm. I forced/turned off with the power button. Turned back on... same problem: fan & indicator lights on, no screen light/image. I'm currently letting it sit for an hour with the battery out and no power cable. What else to try if that fails? Ideas? Both why, how to reboot and what the issue is?
    Master:
  • 397 Answers
The HP DV series or laptop are known to suffer from GPU faults and issues. The syptoms you describe indicate such a fault. To help isolate the fault you will need to try plugging the laptop into an external screen when it is powered off, Power the laptop up and if the GPU is healthy it should display fine on the external screen leaving us free to look at other issues. If it does not it likely your GPU is at fault. If this is the case you would either need to undertake re-ball/reflow repair on the GPU, which is best done by you local repair shop unless you have the tools/skills to perform such tasks. Alternatively replacing the mainboard in the laptop could be an option.
Let me know if you try an external monitor. If it does display I will try to guide you through testing for other faults and issues.
Posted on Jan 09, 2013
Problem with HP dv3 power cables.
Sounds like the charging board may be malfunctioning/shorting out inside the laptop itself causing these ac adapter failures.You really need to have it looked at before other it causes you motherboard to fail or any components connected to it.The power jack may be shorting as well which is attached to the motherboard
Dec 17, 2011 | HP Pavilion Dv3-1075us Notebook
Why does my HP Pavilion leak electricity?
Sounds like a power jack problem where the charger plugs in has a short or is touching other components near it.
Dec 16, 2011 | HP Pavilion dv3-2150us Notebook
My HP w2007 has started clicking to Monitor Going to Sleep and then going blank. I have never known how to wake it up so I have to turn the whole computer off and restart. HELP
Hey there, Normally simply pressing a random key on your keyboard or moving your mouse should wake it up, if it doesn't though I think the easiest way to solve this is to simply turn off the sleep mode after x amount of time.
If you have windows 7, press the start button and type in "power options", go ahead and open power options and there you will be able to set the time it takes before your PC shuts down, and you can also set it to never.
If you still wish to use this feature but just want to be able to it's a bit tricky and it won't even work for all PCs but if the keyboard waking isn't working, then it's probably because your pc does have this feature. When your PC is off, boot it up again and enter the bios by pressing F10 i believe it is for HP. And somewhere you should be able to set which devices are allowed to wake up your computer, all devices are probably disabled now, so go ahead and enable the keyboard to wake up your computer. Now save and exit, and the next time your PC goes to sleep mode you should be able to wake it up by pressing a key on your keyboard.
I hope I was able to assist. If I was, please don't forget to rate this solution.
Jul 28, 2011 | HP Pavilion F1523 15" LCD Monitor
How do I access the fan on an HP Pavilion DV3 Laptop? I've taken it apart with the online guide available but that failed to access the cooling fan. Laptop is overheating and it's clearly the...
Honestly, try harder. If you've taken the thing apart, you're more than half way there. You probably just need to unscrew more stuff and pry more parts out.
Jul 22, 2011 | HP Pavilion Dv3-1075us Notebook
I cannot wake up my HP Pavilion dv3. blue power led flashes on and off and orange connection led too.
The display driver could have crashed, try holding the power button until the lights go off, and the hard drive powers down (you can hear the spinning stop) then try to power it back on. If that doesn't work, do a hard reset, which would be unplugging it from any AC power, and removing the battery and then reconnecting the battery before powering it on. Should this not work, i would say it's safe to assume the backlight is non functioning and a replacement would have to be ordered.
May 05, 2011 | HP Pavilion Dv3-1075us Notebook
Hello, my synaptic touchpad does not work correctly. please help me how to resolve this. thank you
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3860372&
try downloading and install again. if i was helpful please vote..
Nov 01, 2010 | HP Pavilion Dv3-1075us Notebook
I have a hp pavilion a1410n desktop with visat , i
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00845808&cc=us&lc=en&dlc=en&product=1841799
To wake it up,first try just quickly pressing the power switch on front. If worse comes to worse,just turn it off by holding the power button in until the pc shuts down & simply power it back on. Then you'll be able to get into windows & make the proper adjustments for the power settings you want & be able to configure the keyboard to put the pc to sleep or wake it. The above link is straight from hp,reguarding the same issue. I gave it to you for reference.
May 13, 2010 | HP Pavilion a735w (PL308AAR) PC Desktop
Hp pavilion dv4000 will not wake up from hibernation
You have major problems. You should take it to a repair shop as it sounds like your motherboard is fried.
Oct 22, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion dv3z Entertainment Notebook Logo
77 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
